Advice please on MZ3
Posted 02/10/2013 - 17:58
We can't really guess what is wrong, but a good start is to try new batteries. Sometimes if batteries are weak cameras will lock up.
Failing that, it's back to Asahi Photo, Harrow Technical or Newton Ellis and the like for a quote. JPS only do the digital cameras.
Posted 02/10/2013 - 19:46
Sadly that was on a new set of batteries....
Stuart
Stuart
Posted 02/10/2013 - 21:18
SOunds to me like the mirror mechanism is jammed somewhere. I don't know if it will be possible to work it loose by manipulating it manually.
Posted 02/10/2013 - 22:08
It is possibly the dreaded dodgy plastic cog problem that was the Achilles heel of the MZ series. It is possible to get it replaced with a good brass one but at a cost so it depends on how much you value the camera (rather than how much the camera is 'worth' commercially).
K.
K.
13 years
However before putting it in I decided to see if the camera seemed to operate OK. Sadly it does not. The film wind on works OK when you open and shut the back, AF works and bleeps OK but when I press the shutter all I hear is a kind of wine noise for a second or two and the mirror does not go up and the shutter does not fire.
I guess I'm really asking if this is likely to be expensive, even if you can still get Pentax or others to repair them now. Anyone any ideas?
Stuart
