adapter for tokina 500
Posted 31/03/2010 - 23:19
No, unless it is an M42 mount or T/T2 mount, in which case you could the Pentax K mount adaptor. Depending on the lens, you might be able to hack a new mount (most likely for Contax I think).
Posted 31/03/2010 - 23:30
- If it's an M42 mount - YES. K-mount adaptors are readily available.
- If its a T-mount - Most unlikely! these have three set-screws to hold the mount on. Personally. I have only ever seen one (and it's in my own kit)
- If its a T2 mount - YES. I think SRB of Luton still offer them. But a search for K-mount in T2 fitting should find one.
To check, the T2 is actually M42x0.75 mm pitch while the normal Pentax screw mount is M42x1.0 mm. The easy way to measure this without thread gauges is to press a piece of paper against the threads and then measure across as many marks (lines) as you can - then divide by the number of lines. That will be close enough for government work.
Geoff
Geoff
X-5
istDS
K2000
P50.
X-5
istDS
K2000
P50.
If you mean the 500mm mirror lens then it will usually take T2 adapters and Pentax ones are readily available.
Posted 01/04/2010 - 08:45
OOPS!
In my last post I wrote:
I can plead a "senior moment", or that I spent too much time around computers (and count from 0) or that I just failed to check.
Pick any one excuse from three.
Geoff
... measure across as many marks (lines) as you can - then divide by the number of lines ...
This should have been the number of lines, minus one ... measure across as many marks (lines) as you can - then divide by the number of lines ...
Geoff
X-5
istDS
K2000
P50.
X-5
istDS
K2000
P50.
worcestershire
can anybody tell me do tokina 500 lens take adapters and if so what are the chances of getting a pentax one?
phill
