ACD FotoCanvas 3.0
Mac
Posted 20/11/2008 - 11:51 Link
Hello Everyone,
Has anyone downloaded this post processing software, and what did you think of it?
I've been using a VERY basic ACD Editor ('cause I'm a VERY basic guy) and I'm wondering if the above would be a good baby step forward.
Full-blown PhotoShop scares the ---- out of me
Cheers!
Mac from Montreal
Posted 20/11/2008 - 12:29 Link
Mac,
I'd suggest going with Photoshop Elements.
Even version Elements 2 will do most of what you'll need.
Version 3 is also nice.
Elements is *much* easier to use than Photoshop... but both packages work in a similar way so you're better placed to migrate up to full Photoshop when you need to
Gwyn
Posted 20/11/2008 - 12:41 Link
I'd agree with Matt.
If you use Vista though you will need at least PSE6. It is a wonderful application and does pretty much everything you will need, starting with letting it do the work and then trying out things on your own as you gain confidence.
Mac
Posted 20/11/2008 - 13:02 Link
Thanks my Friends,
Off into the wild blue ....... to process it of course - WILDER! MORE BLUE!!!
Mac from Montreal
Don
Posted 20/11/2008 - 14:35 Link
Mac my friend, go look at Wacom's graphics tablets.
They are going at London Drugs and Henry's for as little as $99.00.
Check out what's included in the box.... Most come with a *Free* copy of Photoshop Elements.
You'll love editing with a pen more than the mouse, anyways.
pentaxian450
Posted 20/11/2008 - 17:20 Link
The Wacom Bamboo fun pad comes with Photoshop Element 5 and two other photo editing software. You should be aware that the Wacom graphic tablet driver is NOT compatible with a lot of scanners drivers. You need to verify compatibility of your scanner driver on the manufacturer's web site. They usually have a "patch" to fix any problem that might occur.
Mac
Posted 20/11/2008 - 19:57 Link
Don,
Thanks for the tip - will check it out for sure, Cheers.
pentaxian450 - will follow your advice as well, Merci.
I'm willing to bet that the post processing world is WAY bigger than the camera world.
Just 50 years ago I was kneeling beside our bathtub in the dark developing B&W prints and confused by the "huge" assortment of papers available. That was post processing.
Who knew?
Mac from Montreal
