a good external flash for k200d?
Posted 15/03/2015 - 18:56 - Helpful Comment
I don't find a built-in white reflector card that essential ... It's only useful for catchlights when the flash head is facing straight upwards or slightly forwards ...I find more often I get better results from bounce light off to the side more, so the card would have no effect then. Instead I use a dome -type sphere diffuser which puts light out through the front no matter where its pointed, so I get the catchlights that way.
I believe (but do check) that the new Pentax AF 360/540 II models can use their front facing light both as a video modeling light and also as a secondary forward facing reflector , to provide a little front fill or catchlights, so that would be very versatile to use when you are bouncing off and up to one side.
I can't be absolutely sure about full compatability, but I don't know if any reason why the flash would not work fine on any Pentax DSLR ...I do hope that someone else can back this up though .....
Posted 15/03/2015 - 19:08
Thanks McGregNi. Maybe I'll persist with it then, esp using the LED light in conjunction with bounce flash (and if no one flags up any major compatibility issues).
Posted 15/03/2015 - 19:16
Check the manual, there must be a setting to activate the secondary light ... This may be why the white plastic card has been removed as this new solution is far more versatile. Let us know how it all works!
London
