A flower and a torch
Posted 12/11/2011 - 01:12
Naim, I think the second one is actually better, but I can see what you mean by having the light shining through the translucent flower. The suggestion I would have to avoid the blown area is to either use a weaker light with an appropriate exposure, or to knock the exposure down a stop or so and adjust in post processing. You should be able to get an acceptable result with the ight shining through the petals with no blown area.
Posted 12/11/2011 - 08:21
Naim, could your light source not be moved back & under so that the light still shines though but avoids bouncing off that front "facet" of the flower?
With the continuous light, you can at least see the effect as the light is moved.
Roger.
Roger.
Wakefield,
West Yorkshire
1. Would you leave the first shot as it is?
2. If the answer to Q 1 is 'No' then how can I avoid the blown area?
Cheers.
[IMG]http://i376.photobucket.com/albums/oo209/Naim-Khan/NK012581.jpg[/IMG]
[IMG]http://i376.photobucket.com/albums/oo209/Naim-Khan/NK012589.jpg[/IMG]
