A "kicker" for a Cocker
Posted 29/05/2017 - 22:17 - Helpful Comment
I like the rim light! Its rather glamorous actually It may be perhaps 1/2 a stop too bright (?), but the play of light and shadow over the subject is very good I think. Good to see your explorations continuing in such a positive way.
Posted 29/05/2017 - 23:12
Thanks Nigel. Yes he seems to have aquired the Bonnie Tyler look in this one !
I did try and damp the highlight a bit in PP with Silkypix but couldnt adjust it satisfactorily. It didnt show as blown in the histogram on the camera so I think it is right on the edge.
Posted 30/05/2017 - 10:31 - Helpful Comment
Just love people experimenting with light....
Stuart..
Stuart..
Posted 30/05/2017 - 11:28 - Helpful Comment
I agree totally Stub! I still see comments from time to time from people who think that the latest DSLRs and their superb high ISO performance mean that flash is no longer needed ....
No, it's not like that at all! I think that digital technology has revitalised the use of flash, and more sophisticated use of flash as well, by helping us all to see the effects quickly and experiment. Also higher ISOs just mean we can get more power and performance from our flashes without losing the dynamic range and limiting noise for our flash images.
So the better performing cameras actually enhance and go alongside the greater use of flash .... The two are interconnected. Having a new, high performing DSLR is the best excuse for starting out with flash!
Posted 01/06/2017 - 01:15
You should try cross lighting with your four legged friend. The result is often surprisingly good with dogs.
Here is the set up: two flashes at head level in line and pointing toward each other with the head of the animal in the middle of the line.
It will give a very even exposure on both side of the head with a darker line in the middle of the head, if the animal is looking directly toward the camera. The width of the darker line can be varied by slightly moving both flashes forward or backward. By moving one flash forward and one backward, you can move the darker band right or left. The results is sometimes unpredictable, but always interesting, but not always what you expect. Surprisingly, very often, P-TTL works decently with cross lighting, so you can use it as a baseline and correct the exposure with different compensation on each flashes, or flash compensation on the camera for overall correction.
Light boxes or umbrella don't really work with this set up because they change the point light to a rather large beam, eliminating the darker band on the animal portrait.
For best results, I recommend using a flash meter in manual mode. It gives more predictable results. This set up can also be used for portrait with very good resuts.
Posted 01/06/2017 - 01:53
Thanks for that suggestion Yves, I will put that in my notebook to try out.
20 years
Surrey
Once I have got the hang of a few techniques I may venture towards human subjects !
Appreciate any comments as usual.
