Some quick help (I hope)
Posted 27/10/2008 - 07:18
Looks good - pity about the exchange rate!
Thanks for the link.
Posted 27/10/2008 - 08:39
Thanks Gwyn.
I actually came round to looking at
http://cgi.ebay.co.uk/4-Channel-Wireless-Flash-Trigger-F-Canon-580EX-II-430EX_W0...
after Hefty's advice. If the one you refer to is free carriage then I'll go for that but I'm struggling to see the delivery fees.
Posted 27/10/2008 - 08:52
I don't think carriage is free, but you do get a discount as a PU subscriber.
Personally I'd go for something UK based over something Hong Kong based, but that's just me.
Posted 27/10/2008 - 09:07
In fact postage is £3 so I'll probably go with the Chinese option. I've had stuff from China before and indeed got into mild negotiations with a manufacturer of some excellent cleaning products with a view to importing them. But the up front cost of about 4k put me off, large minimum orders.
Posted 27/10/2008 - 20:16
That's more than I want to spend but I am seriously tempted as you know where you stand with a cable the darned thing will work and not be fussy.
I wish I could find a simple extension cord that would just fire the flipping flash and let me sort out the exposure.
Posted 28/10/2008 - 10:24
Mike,
Assuming you are talking about a dSLR and the AF400FTZ, then since you can only use "A" or "M" on the flash then a simple "PC" cord will do the job.
Often camera shops will have a bucket full of them for next to nothing
You will need the hotshoe adapter (I got one thrown into an ebay camera kit I bought and sold the parts on), and one for the flash - but these are easy enough to come by. Hama make modern versions of them.
e.g. Camera hotshoe adapter
5m PC lead
(Can't find the PC-to-flash adapter at the moment)
There's also this (but may be for studio flash units only - not sure).
Hope that helps!
5m PC lead
Hope that helps!
Posted 28/10/2008 - 11:40
Matt - it sort of helps!
Right re-reading your post I think I get it:
The cord is a crappy simple cord easy to get.
The hot shoe adapter gives you a hole to plug the simple cord into
What you can't find at the moment is the thing I'd plug into the 5 pin socket on the flash gun.
Is this 5 pin connector Pentax specific or an industry standard?
At £34.50 your other suggestion is ruled right out!
At worst I'd use a radio one from China at £13 or so.
Hefty's suggestion would be ideal except it does all the complicated PTTL stuff as well which I really don't need or want or want to pay for.
I'm wondering if I can't butcher something and make an extension cable.
Thanks to all so far.
Posted 28/10/2008 - 12:00
Mike,
The flashgun end should be the simple PC plug to hotshoe. You won't get PC-to-5pin
The Pentax flashguns will work with "dumb" cameras that only have the centre pin - ideally you'll need a plastic adapter since shorting out the Pentax-specific pins can cause a little havoc
But again, if you know what you're looking for you can often rummage around in a camera shop.
Posted 28/10/2008 - 12:05
I haven't got a simple hole in the gun!
Which I assume means I need a hot shoe adapter for the gun to slip onto which does have simple hole plus the same sort of thing camera end. I'm being dense I know I am. I think I need to go to a shop and rummage.
What does PC stand for?
Posted 28/10/2008 - 12:11
Prontor-Compur, a standard connector type for photographic flash synchronization.What does PC stand for?
Hope that helps
Worcestershire
Cable is fine and radio thingy is fine but cheap is essential!
Many thanks.
