8028
womble
Posted 14/01/2022 - 18:27 Link
Ever wondered what happens when you accidentally set the focal length of the lens you are using to 8028mm instead of 28mm? Well now you know...
8028 par Kris Lockyear, on ipernity
pschlute
Posted 14/01/2022 - 19:36 Link
Interesting
kea828
Posted 15/01/2022 - 18:05 Link
It would be interesting to see how it differs from a setting of 2.8.
Regards,
Kea828
pschlute
Posted 15/01/2022 - 19:01 Link
Just claim it is ICM Kris
Edited by pschlute: 15/01/2022 - 19:04
pschlute
Posted 15/01/2022 - 19:04 Link
Under reporting the SR setting (not sure if 2.8mm is possible) will have no adverse effect on the image. The reason is that the sensor shift will be minuscule.
This is why when folk ask what they should set a zoom lens to, if they are using all of its range and do not wish to change the setting for each picture, the answer is to set it to the lowest zoom FL
Edited by pschlute: 15/01/2022 - 19:05
kea828
Posted 16/01/2022 - 13:24 Link
Thank you for explaining that. Very useful.
Regards,
Kea828
HarisF1
Posted 16/01/2022 - 18:42 Link
Is this set on a Q camera? I didn't think it was possible on a K mount digital camera.
Edit: Looks to be shot on a K-3 iii, is this the only one with this setting?
All the gear with no idea
Edited by HarisF1: 16/01/2022 - 18:44
womble
Posted 16/01/2022 - 22:37 Link
The K-3iii gives you four digits to set for the focal length rather than the set list like the original K-3. As I was changing it from 50mm to 28mm I accidentally set the first digit to 8... I was very glad when I realised what I had done as my initial reaction was something dire had gone wrong.
