64GB SDHC Cards
Posted 24/02/2010 - 14:14
I believe that it is NOT compatible with SDHC compliant devices.
If the changes are just firmware rather than hardware, will Pentax issue an update for existing cameras?
Posted 24/02/2010 - 14:25
No 64GB is not in the SDHC standard.
SDXC is for 64gb and up and Thosiba announced they will have those this summer.
SDXC will probably also work with some SDHC devices if you reflash the system file format to FAT32 since the standard for SDXC is exFAT, one of the reasons is because exFAT doesn't have the 4gb file limit.
I ain't sure if the device need to support exFAT to get the SDXC label (support) on it?
If the answer is yes then we will probably never get an update to SDXC with the current camera's since it's a bit more complex then going from SD to SDHC.
Posted 24/02/2010 - 14:35
The largest capacities never provide the best value in terms of pence per gigabyte, so I expect I will always use a lower capacity than whatever the biggest card is of the moment. It also spreads the risk to use more than one card.
~Pete
Posted 24/02/2010 - 15:37
Not if you're like me... It also spreads the risk to use more than one card.
I've one card of 8GB that's my main card it's in my camera or in the computer and no where else or I might lose it
I also make a poll here about SD card failures and it seems you must be extremely unlucky if your card would fail.
https://www.pentaxuser.com/forum/topic/sd-card-failure-17511
27 votes and 4 voted that 1-3% of their cards failed and the rest had no failures.
Posted 24/02/2010 - 15:45
Don't forget that when the 1-3% of cards that fail happens to be that 8MB card, that for you it will be a 100% failure rate...
Posted 24/02/2010 - 15:50
Indeed but if I lose a one of the two 4GB card that would also mean losing 50% of my photos and that's far more likely to happen then that the card would fail to work
Posted 24/02/2010 - 18:30
Why on earth would you want a 64gb card in your camera? I rarely even half fill my 8gb card and that is with lots of old junk I haven't got around to deleting yet! I suppose the video fraternity might find them more useful.
K.
K.
Posted 24/02/2010 - 19:39
64GB holds only about 2 hours of top quality K-7 video. You might also want a gigantic amount of space for RAW stills for a holiday or expedition.
EDIT: Ok, it would be a really good holiday to need all that for stills
~Pete
Posted 24/02/2010 - 20:22
You never know how high the resolution would be of the sensor over a year, they are already going near the 20mp with the APS-C sensor.
Posted 24/02/2010 - 20:32
The only current reason for a 64gig card I can see is as a solid state hard drive in a net book or the like.
But when the behemoth full frame sensors and the new 645d hit the market....
Cheers, HG
PPG entries.
PPG entries.
Posted 24/02/2010 - 22:47
I managed well over 40GB on my last holiday ... but would I trust that to one card? Probably not - although I would copy it daily and keep the images on the card to ensure I had two sets.
link
To think, less than 7 years ago a 1GB card was running close to that price.
The Photomonk
