'raw' paint
trickletreat
Posted 07/07/2011 - 11:32 Link
K5 DA55mm/1.4, iso200, 1/1600s, f/2.2, strong sunlight
[IMG]http://img.photobucket.com/albums/v425/inamini/IMGP0282.jpg[/IMG]
The top of her head is very bright, I have tried some pp in iphoto. Would I be able to improve this type of picture by shooting in RAW and using Aperture on the mac?
I am not sure if the bright are detracts from the image, and am happy with the isolation from the background.
Nigel
techno-terminator
Posted 07/07/2011 - 11:45 Link
I've been stunned at the difference I get using RAW and Aperture - don't know if it's because I'm a better 'shooter' now, or it really is because I now shoot RAW.
Yes I do 'tweak' them - but my piccies are no longer flat - they have more life in them .
All I can say is - have a go , you may find you've gained a lot , but unless you try it you won't know
Now you can get Aperture from the App store it's no longer the nasty shock it was - the trial may well convince you - so go on - you know you want to - have a go
let the education continue
Pentaxophile
Posted 07/07/2011 - 13:01 Link
If you do have the image in RAW, email me and i'll have a go. But it looks like it might be a borderline case and the middle of the bright areas may be irretrievable.
Ideally you should have metered from the bright areas then hit AEL or switched to manual with the same settings. With the k5 you may be as well setting the camera to deliberately underexpose then boosting exposure afterwards in PP.
Posted 07/07/2011 - 13:17 Link
I tried to have a play with the jpeg picture and found it a little too far gone to bring back and do any justice to it. As Pentaxophile said shot it under exposed and adjust in Lightroom or Aperture afterwards
PPGlink
Pentax K-5 with 18-50mm & 50-200mm Kit Lenses, Pentax 55mm f1.4 SMC DA* SDM Lens, Pentax DA 12-24mm , Pentax DA 35mm macro, Pentax SMC FA 77mm Limited, Pentax SMC FA 43mm Ltd, Pentax SMC F 50mm, Sigma 24-70mm, Metz 58 af-2
trickletreat
Posted 07/07/2011 - 13:53 Link
Thanks for the replies, advice and offer. I think it will be wise to shoot in both in the future, then make a decision re aperture.
Nigel
Pentaxophile
Posted 07/07/2011 - 14:01 Link
This is a quick jpeg edit in PS using a duplicate 'multiply' layer to make the image denser/darker, and then erasing the shadow areas. Comment Image
I had to crop the worst bits out, but I prefer the more intimate crop anyway. The top of the forehead and hair would only be rescuable in RAW, if at all! Hope you don't mind my intervention.
trickletreat
Posted 07/07/2011 - 14:38 Link
Nice work, that is a better composition, and removes the problem areas.
trixie
Posted 29/07/2011 - 09:24 Link
Nigel, in the K-x there is a raw and Jpeg programme that you can use have you found that one yet in your camera you have a K5 it will probably have the same setting, cheers Trixie :
trickletreat
Posted 29/07/2011 - 09:32 Link
Hi and thanks, yes I have, but I was unsure if saving to the card in both would cause a delay between shots.
Pentaxophile
Posted 29/07/2011 - 09:51 Link
It doesn't cause much of a delay. You'd notice if you were in continuous shooting mode, but otherwise probably not.
trickletreat
Posted 29/07/2011 - 09:55 Link
Thanks for the info. It is a fairly large fast card.
