*istDS low sensitivity on start up at night
Posted 30/03/2006 - 14:17
If you don't have another lens to try, I would try cleaning the electrical contacts between the lens and body. Some strange exposure issues will result if the body cannot communicate effectively with the lens (and as a side issue, I know there have been some compatibility issues with Sigma lenses. I'm not sure though if your combination is one of them - maybe a search on the 'net will help).
Also, double check your exposure setting (I presume you are using "P", or green).
Posted 30/03/2006 - 14:25
Thanks for the quick response
I also have tried it with a SMC Pentax-FA 1:1.4 50mm with the same problem. The sensitivity seems to get better the longer the camera is on, but still appears washed out (low constrast). I think I may have to get it fixed under warranty.
Posted 30/03/2006 - 16:07
Mark,
Yes, it sounds like a warranty repair. If the FA50/1.4 messes around, then it looks as though there's a real problem.
Posted 01/04/2006 - 18:03
My pop-up flash on my DS stopped working within a week of buying it. Pentax Slough replaced the whole body under warranty.
If my addled memory serves correctly there seem to have been quite a few posts on this forum and in "other places" where people have reported various problems with the built-in flash on the DS, maybe there is a design fault or quality control problem at pentax?
20 years
The camera is set for default everything. Lens is Sigma 18-50mm/1:3.5-5.6
I have upgaded the firmware to 2.0 but this has not corrected the problem
