*ist Lens hoods
Posted 17/10/2005 - 11:35
Greetings one and all
Am now the proud owner of the above camera and a delight to use but Please: Can anybody explain the reason for the small manufactured removable panel in the lens hoods?
many thanks
John
It's so you can rotate a polarizing filter if you have one fitted Greetings one and all
many thanks
John
Kim
Posted 17/10/2005 - 11:42
My sincere thanks Kim for such a speedy reply and of the info supplied..
John
John
Posted 17/10/2005 - 14:57
It also allows you to use manual focus if you have the lens hood stowed backwards on the lens, and makes putting on or removing the lens cap with the hood in place much easier.
If you're a bit slow on the uptake like me, you might like to know that the lens hood obscures the built-in flash at the wide end. Not that you'd usually need a lens hood and flash at the same time, but it can ruin a flash picture if you leave it on.
http://www.siblog.co.uk/
http://www.siblingmedia.com/
21 years
Nr: Birmingham
many thanks
John
