*ist D Questions
Posted 07/05/2008 - 21:41
Maybe you could send a PM to Pentaxke - he is our ïst D expert I think!
Posted 07/05/2008 - 22:21
The flash stopped working on my istD earlier this year.
Although non-PTTL flashes and pc-sync'd flash did work, the PTTL AF360FGZ and AF540FGZ would not fire at all.
I guess firstly, make sure some internal memory isn't causing problems... Remove the battery, wait a few minutes and replace. Then find the reset to factory defaults within the menus and do that.
Dunno about the other issues, but off hand, it sounds like it needs repair.
Posted 07/05/2008 - 22:30
No 1. Sounds like a problem.
No 2. You have to set it to allow the use of the aperture ring. Scroll through the menus to find the setting.
No 3 If you can find one to fit, of course.
Posted 07/05/2008 - 22:34
2. Why wont it work with non ka/kaf lenses?
Try the instructions here - https://www.pentaxuser.com/forum/viewtopic.php?t=7719 - except subsitute "AE-L button" for "Green button".
~Pete
Posted 08/05/2008 - 06:25
3. Can I use a CF to SD adaptor in it?
Yes. I have one 3. Can I use a CF to SD adaptor in it?
There are two types of SD-to-CF adapter. One will make the SD card stick out - that won't work. The other, the SD card sits inside and works a treat in my *ist-D
Might be able to dig out a link later...
Posted 09/05/2008 - 15:32
Cheers for the replys also i took apart some old CRV3 baterrys and found they are literaly 2 AA's taped together! is there any advantage using these over AA photo lithiums and can you still get the battery grip BG-1 at a resonable price in the UK?
Miranda MS-3 35mm
Pentax *istD
Pentax MX 35mm
Richoh KR-10M 35mm
50mm SMC ASHAI PK
28-70mm Miranda PK
18-55mm Pentax DA
28-70mm CPC AUTO ZOOM PKA
80-200mm Hanimex PK
135mm Panagor PMC AUTO TELE PK
Too many flashes to count!
Pentax *istD
Pentax MX 35mm
Richoh KR-10M 35mm
50mm SMC ASHAI PK
28-70mm Miranda PK
18-55mm Pentax DA
80-200mm Hanimex PK
Posted 09/05/2008 - 15:46
Do you mean the CRV3's or the button cell?I guess firstly, make sure some internal memory isn't causing problems... Remove the battery, wait a few minutes and replace.
Miranda MS-3 35mm
Pentax *istD
Pentax MX 35mm
Richoh KR-10M 35mm
50mm SMC ASHAI PK
28-70mm Miranda PK
18-55mm Pentax DA
80-200mm Hanimex PK
Pentax *istD
Pentax MX 35mm
Richoh KR-10M 35mm
50mm SMC ASHAI PK
28-70mm Miranda PK
18-55mm Pentax DA
80-200mm Hanimex PK
Posted 09/05/2008 - 16:32
Oh yeah, forgot about that one. Not sure if the button cell helps anything more than the internal clock. I am not certain, but I believe that I remember when I first got the istD the settings would remain, but the clock would need to be reset every time I replaced the CRVs. (I got it with a dead backup battery).
Anyway, it certainly couldn't hurt to do both. Its a long shot to begin with, but I have read of more than a few cases where odd behavior was resolved by removing batteries and resetting defaults or both. (had a few personal experiences myself such as when the Av/Tv dials stop working for no reason)
Good luck, hopefully it is a simple user-solvable problem.
Posted 09/05/2008 - 20:35
I've been playing with the flashes my Miranda 700CD wouldn't work on it nor would my days 700CD! my brothers would though! also my 1/2 broken jessops fash worked & my brothers Thyrister Flash! i am going to see if i can swap with him as mine works fine on his Olympus FTL!
Thanks For the help
Thanks For the help
Miranda MS-3 35mm
Pentax *istD
Pentax MX 35mm
Richoh KR-10M 35mm
50mm SMC ASHAI PK
28-70mm Miranda PK
18-55mm Pentax DA
80-200mm Hanimex PK
Pentax *istD
Pentax MX 35mm
Richoh KR-10M 35mm
50mm SMC ASHAI PK
28-70mm Miranda PK
18-55mm Pentax DA
80-200mm Hanimex PK
nr. Wallingford,
Oxon,
UK
1. why won't any of camera flashes work - hot shoe & sync lead 1980's dedi and 'standard'?
Note i have just upgraded to the latest firm ware- this should have solved these shouldn't it?
Thanks David
Pentax *istD
Pentax MX 35mm
Richoh KR-10M 35mm
50mm SMC ASHAI PK
28-70mm Miranda PK
18-55mm Pentax DA
80-200mm Hanimex PK
