*ist D - HELP!
Posted 20/02/2004 - 06:39
I had this fault with mine and it turned out to be a problem with the contacts on the camera body and any lens I used. I returned it to Camerworld and it was replaced by return.
The camera behaves as if no lens is attached.
I suggest speaking to the supplier and asking for a replacement.
Posted 07/03/2004 - 02:38
I know this is late, but the issue sounds to me like the aperture ring is not on A. and if this is a manual lens then you have to set the mode to hyper-program mode and set it to work with "other than A" on aperture.
Posted 10/03/2004 - 02:47
Hi All,
Been away for a while....
yes i think the previous post by "Guest" is right. If you are using a lense with an appreture ring, you must set it to the "A" position. Buy defaut the *ist-D is set to operate with this setting.
Rgds.
Rgds.
http://www.photonski.com/shotgun
http://www.pbase.com/santyluib/first_istd_sample_photos
"It's only a Pentax!"
24 years
