Focus within magnification
Posted 11/06/2014 - 12:27
First thing to do if you haven't done so already is to calibrate the AF.
You be able to see from the photos whether they are front focussing or back focussing.
Take a bunch of pics at widest aperture in daylight and adjust the AD calibration ( custom menu #26 ) between +/-10 until it focusses correctly.
You're not going to see if anything is in focus or not in lightroom at 11:1 zoom as it's just blocky pixels ( each sensor pixel is 11pixels square on your monitor )
Posted 11/06/2014 - 12:48
Smeggypants - seems so simple and don't know how I didn't discover this - my setting was on OFF! Allow me to say it - Idiot!
I have read up in the manual and will test at the first opportunity, but just one more thing please - will this also automatically correct when using the MF setting?
Thanks for explaining about Lightroom at 11:1 magnification, but then what is the largest magnification that one should use please?
Pentax K5, Sigma 18-200mm f3.5-6.3 DC lens. Manfrotto tripod & cable shutter release. Lightroom V5.
Posted 11/06/2014 - 23:32
If you mean 'will it affect the way the focus indicator behaves in manual focus' then the answer is 'yes', any adjustments will impact on this so your manual focus may become more accurate if you rely on the focus indicator rather than looking at the focussing screen in the viewfinder.will this also automatically correct when using the MF setting?
Posted 12/06/2014 - 01:56
David,
Thank you for that information. Must say that I prefer to use AFS to MF, but Im glad of any measure that assists.
I'm currently identifying what calibration appears to be best (its not easy!) and I'm at the + end of the scale at about 9 or 10. My eyes are good as I don't wear glasses but even so I think I need a better pair! No doubt the resulting photos should get the answer from other folks.
Keith
Keith
Posted 12/06/2014 - 02:32
1:1 will give you 1 image pixel per screen pixel. anything higher than that and you're not gaining anything really. however it is useful sometimes to zoom in higher more easier and more accurate painting of the local adjustment brush
Posted 12/06/2014 - 03:05
Thanks so much for your time and help. Your idea about the use of the adjustment brush with higher magnification makes sense.
I have I believe sorted this problem in the camera - seems I need to adjust by +9.
Keith
Keith
12 years
Gold Coast,
Qld
Since then I have tried to take photos on AFS and MF and find that they are indeed blurred when magnified in Lightroom to 1:1 and above.
My questions are: to what degree of magnification should a well focused shot with my camera and lens still be in focus? I would like to think that it would be to Lightroom's 11:1 magnification and wonder whether its the camera or the lens or the combination of both at fault?
