How many Pentax lens lines are present at the moment?
Posted 19/12/2006 - 15:11
Welcome to the board
For technical information: http://www.bdimitrov.de/kmp/index.html
Optimised for Digital - there are two issues with lenses and digital. Firstly, because of the depth of the CCD and IR filter the image needs to be fairly well collimated. Film can produce a good image at the edges even when the incident angle is not at 90 degrees. Digital, on the other hand, works best when the image arrives at close to 90 degrees. Coated elements etc can also help reduce stray light that might otherwise create ghosting or fogging at the CCD.
Secondly, most CCDs (including Pentax) are APS-C sized, not 35mm size. The lenses can be made smaller, lighter, and often better quality because their image circle is reduced. (see my later comments on the 16-45 on film though!)
Pancake - unique (?) Pentax design that produces an unbelievably thin design.
Limited Lens - Pentax apply better coatings, usually more aperture blades, and a more "engineered" construction. Pentax Limited lenses are generally superb (I can only speak from hearsay as I don't own one )
Interestingly, most of the SMC-DA (digital only) lenses can be used on film bodies too - contrary to what others may tell you However, since the SMC-DA lenses do not have an aperture ring, the bodies you can use them on is slightly reduced. If you have the Z1, Z1P, or any of the other bodies that allow aperture control from the body, then there's no problem.
For example, check out my early test of the SMC-DA 16-45 on a Z1 film body: http://www.pbase.com/mattmatic/smc_da_test
On the other hand, I think every Pentax K-mount lens ever made will work on the digital bodies. There are some caveats and restrictions, but essentially there's nothing to stop you using fully manual with older lenses on the dSLRs. Cool
This topic has been covered in various guises, and if you need more info I'm sure I can dig up some older threads
Posted 19/12/2006 - 16:36
From someone who has the 31 ltd, 43 ltd , 77 ltd and 50/1.2 special which is similar, they really are quite superb.
Kim
Kim
Posted 19/12/2006 - 17:16
Kim,
Shhh! You'll get my LBA going again
Posted 19/12/2006 - 17:30
MattMatic wrote:
Kim,
Kim,
What with something like this: http://www.bdimitrov.de/kmp/lenses/primes/normal/A50f1.2-Special.html
If you think the 1.4 are sublime.
Kim
Posted 19/12/2006 - 17:47
LOL - there's still a regular one of those sat on a certain shelf in Watford...
Spirit_of_will
My Flickr
My Flickr
Posted 19/12/2006 - 21:18
As far as Pentax lens lines available today, or tomorrow, the alternative thread under Pentax Lenses https://www.pentaxuser.com/forum/viewtopic.php?t=3424 has a couple of useful links from Ammonyte.
Malcolm
Life? Don't talk to me about life!
Malcolm
Posted 19/12/2006 - 21:22
Only because I don't have £400
Optimized for digital performance.
Pancake lens
Limited lens
Are they all full frame 24x36 or are some limited with their fingerprint?Where can I find information on these lenses. What are the Pentax lens lines available today. Are old lenses not suitable for digital photography?
Thanks in advance.
