Why millimetres?
HarisF1
Posted 29/10/2018 - 16:48 Link
Here's a random thought I've just had - it's peculiar that we refer to focal lengths in millimetres instead of centimetres. I've got a couple of ideas as to why, but it's still funny.
I mean, doesn't anyone else want to buy a new D-FA 7-20cm f/2.8 lens?
All the gear with no idea
derek897
Posted 29/10/2018 - 16:57 Link
Too many inbetween focal lengths, I'd say.
Just off the top of my head, there's
14
15
16-
17-
18-
19-
21
24-
28-
35-
43
55
75
77
105
What were they before everyone went metric ?
Posted 29/10/2018 - 17:17 Link
A 50mm lens is a 2 inch lens, a 150mm lens would be a 6 inch lens. Or we could use 5cm and 15cm, and usually on pre-war lenses you are likely to find focal lengths in cm. Post-war we went to mm.
It doesn't really matter as long as we have consistency and we all know what we are talking about.
MrB
Posted 29/10/2018 - 17:49 Link
And print sizes are often quoted in inches, e.g. - 16x12, 12x8, 10x8, 8x6, 7x5 and 6x4.
Philip
petrochemist
Posted 29/10/2018 - 18:00 Link
Millimeters are the preferred SI unit of length that is appropriate for typical lenses. Centimeters while still a recognized SI unit have not been a preferred unit since the old CGS reference was replaced by MKS back in the 1940s. The full SI system being adopted in the 1960s
Older lenses are often marked in cm or inches. Using the base unit of the meter would give us nasty decimals for nearly all lenses. (Less than 1% om my 'lenses' have round figure focal lengths in meters, both of these are actually telescopes one 1m-4m with the eyepiece & the other fixed at 1m without an eyepiece).
Preferred multipliers are multiples of 1000, giving us:
Kilo, Mega, Giga, Terra, Penta... going up
& milli, micro, nano, pico, femto... going down.
Edited by petrochemist: 29/10/2018 - 18:03
pschlute
Posted 29/10/2018 - 18:13 Link
Going off on a tangent here , but it always amuses me that newspapers (and online media) in the UK when reporting on an aircraft story, almost always report the altitude in metres. This is despite the fact that the entire world, with the exceptions of Russia and China fly to the altitude measurement of feet.
Edited by pschlute: 29/10/2018 - 18:13
johnha
Posted 29/10/2018 - 18:20 Link
Most consumer zooms don't match their descriptions anyway - many of the xx-300 zooms from the '90s only went to about 265mm when tested. As John points out, many pre (and possibly post) war lenses were identified in centimetres (and are still advertised as 2.8, 3.5 or 5cm lenses by some dealers). Many Russian lenses are known by their names rather than focal lengths - Jupiter-8, 9, 11 or Helios M44-2 (which was 58mm) for example.
Edited by johnha: 29/10/2018 - 18:41
johnha
Posted 29/10/2018 - 18:29 Link
Aviation is a funny one, altitude is in feet, speed in knots & Mach, visibility in metres, distance in Nm, fuel volume is measured by weight and drinks are often measured by the Oz.
Similar examples are when they use both but round one up/down incorrectly: "1000lb (455Kg) WWII bomb destroyed by controlled explosion in . The 455Kg (986lb) bomb was detained by the Army's bomb disposal team..."
stub
Posted 29/10/2018 - 18:32 Link
Not heard any mention in the current Brexit stategy to make any amendments....!!
Stuart..
Edited by stub: 29/10/2018 - 18:32
pschlute
Posted 29/10/2018 - 18:40 Link
Indeed and even zooms of today can have a much shorter FL when close focussing due to focus-breathing
Kim C
Posted 29/10/2018 - 19:03 Link
Maybe the flying has to do with the fact that the aviation industry worldwide use English as a language.
Kim C
Posted 29/10/2018 - 19:11 Link
Not funny really. Actually there is a great deal of logic behind it. Knots are nautical miles per hour. This makes it much easier in long distance flight because the way lines of latitude are drawn. Separating altitude in feet and vis in metres means there is much less confusion on both the departure and arrival especially when English is not the native tongue. On a modern airliner, nearly half the weight on take off is fuel. The weight of the aircraft is critical the speeds etc. At altitude flying mach is critical not only because most fly close the the transonic region. It also make navigation much easier. 0.8 Mach = 8 miles per minute.
Never drank whilst flying so that one is useless. lol
DOIK
Posted 29/10/2018 - 19:19 Link
I wonder what the charge was...…..Boom Boom
John
pschlute
Posted 29/10/2018 - 20:09 Link
The main reason is that early aircraft navigation relied on the same ideas as navigation at sea. Thus knots as the standard measurement of speed. Aircraft up to the VC10 still had a sextant installed for navigation if so required. Sometimes it was.
Kim C
Posted 29/10/2018 - 20:14 Link
So did a few others. Always a great source of fun for pilots. As soon as the nav said to keep it steady so he could take a "shot", the autopilot came out.
