Vivitar pk fitting wont fit on my KX?
Posted 26/12/2010 - 11:14
It has to be cut off
If you search Google you will find
that it's well documented.
Posted 26/12/2010 - 11:28
Nimitz wrote:
Last night I resized the flange with a small saw.
First I unscrewed the flange to avoid any dust on the inside of the lens. Then it was easy going. (10 mins).
Second I checked for that famous pin to block my AF slot. Luckily it didn't had a pin.
I snapped the lens on my k10 - and it is now working - nicely.
Thanks all!
Thanks all!
A quick search of this forum.
John
roscopecotrain
Member
Wells, Somerset
It looks like the flange in the 2nd picture is to long and that is what is causing the problem.
All help is much appreciated.
Pentax KX Black 18-55mm DAL
Panasonic FZ28 Superzoom
My Flickr
