Very informative links about formatting SDHC and SDXC cards - worth reading!
I would never format one of my cards in a computer.
Agreed, but it does not always work, and there are lots of stories/hearsay as to what you should/should not do - and those pages give some inkling of what might have gone wrong and how to avoid that happening.
Is of particular relevance if, like many of us, you use a number of cameras (and not always all Pentax!) and don't/can't keep track of which cards have been used in which bodies.
K-3 II, K-3 and a K-70 from SRS
If a card shows any sign of trouble, it goes straight in the bin. I did find one card that would format in one K-5 but not in another, so it was taken out of service.
That page then points to this page from the SD Association about a special utility for formatting SDXC cards
I use this on all my cards, it's faster than doing it in the camera because it's right there after I unload the card onto my PC, a simple click on the SDFormatter and it's done. You can also write a label (volume) name for the card. It's 100% safe because it's designed to correctly format the card. Never had a problem with any card on any camera after using this utility for a year or so. Recommended.
I doubt Pentax officially told you to always use the computer.
I would like to ask you Steve, what is the SD formatter utility please?
See the third link in my initial post.
John
► https://www.sdcard.org/downloads/formatter_4/
The reason I doubt Pentax told you this is because it is [a] Contrary to the manual and [b] because they incorporate formatting in the camera firmware (menu) itself.
It would be illogical for anyone from Pentax to insist that you always format via the computer.
The cameras appeared to have automatically formatted the cards on first use ?
But I think we're talking about 're' formatting after transferring photos to the PC.
Correct, no need to format on first use, but no auto formatting takes place - they are pre-formatted based on the specifications stipulated by the SD Association and are ready for use..
Many thanks for clarifying that, Steve,
However, I find that good quality SDHC cards are so cheap these days (in relation to the value of our equipment) that I just buy new ones and keep the used cards as an additional backup (I know people say they have a limited life but that is still a useful fall back). After all, we never re-used our film negatives did we !
They may be cheaper today than they once were, but they are still too expensive for me to keep buying new ones when I fill them. Besides, Hard Drives are much cheaper per GB.
Still, horses for courses - if you prefer buying new cards then that's fine with me
Good quality cards may be cheap, fast cards are not so cheap.
jeallen01
Member
W.London
One of the responders then points to this Wikipedia page with a lot a (pretty technical!) info on the various types of cards, and
That page then points to this page from the SD Association about a special utility for formatting SDXC cards - which, it appears, can be "damaged" by using the normal formatting utilities in the Windows and MAC OS systems!
Worth reading if you are using SDXC cards in particular, or if your computer does not run a Windows or MAC OS!
