Trying Out a Cosina 20mm f3.8
Old ultra-wides, especially third-party ones, tend to perform quite poorly. You need to get them already understanding that they'll probably need to be stopped down to f/8 or f/11 at all times. As long as you understand that then it's fine, they are what they are.
As for the 20mm, Cosina made some fine very lenses and this 20mm isn't as bad as some reviewers would suggest. I find many of the disparagers tend to be - let's say - a tad pompous (just my view) and look down on some of these lower priced but otherwise fine lenses. It's good to experiment and make your own mind up. The best 20mm lens after all is the one you own - not the one you might lust after!
The Pentax DFA 21mm f2.4 is just about the pinnacle of quality for a prime at this focal length (give or take a millimetre) and at wider apertures the Cosina is no real match - but stop it down a bit and it's well capable of producing some very nice results. Bang for buck it's worthwhile having it in the arsenal - this shot taken with the Cosina was a POTW on here a few months back...
A stunning image Lenny but would the same shot with the DFA21mm look any better or more to the point would anyone looking at side-by-side identical photo's taken with the Cosina and the DFA be able to determine which lens shot which photo? I suspect it would be guess work. That's not to say I think the Cosina to be better than the DFA, that would be nonsense but in the right hands, even an older and less sophisticated vintage lens can produce stunning results as you have illustrated.
4 years
