Trailing curtain sync on K3 Mkiii with Pentax AF540FGZii
As far as two flashes, I think you are mistaking the pre-flash for the first one. It wont contribute to your exposure as it takes place while the mirror is down.
I dont use trailing shutter sync often, but seem to remember it is a P-TTL only mode on the Pentax flashes. I would need to find the manual to check.
Thank you Pschlute. This is helpful. I checked the manual again and I can find no reference to trailing curtain sync being a PTTL only function in the sync mode section, which, reasonably enough, was the only bit I read for my particular project. However, this does match the reality of the situation and when I read the flash mode section, there is a table of functions available for each mode, which shows that trailing curtain sync only has a tick in PTTL mode. (Clearly, I must read and memorise manuals more comprehensively - Oh Joy!!)
I scoured the Pentax forums before posing my question to see if my problem had arisen before and there is one about the first flash being a pre-flash that has no impact on the picture being taken, I did some little tests in the house which showed that the first flash does in fact expose the scene, as well as the second. This might still be my problem and I probably need to read even more of the manual and to practise more ‘in the field’. Thanks again for taking the trouble to provide me with a very helpful response.
The trailing curtain option is only a P-TTL mode so not available when the flash is set to Manual output.
What exposure mode are you using on the camera itself ..... Manual ? If so what shutter speed are you selecting.
Also what lens ?
https://www.pentaxuser.com/article/complete-pentax-flash-guide-946
Looks, unfortunately, that Nigel is no longer active on this site. Or PF for that matter.
Just a thought....you are not turning the LED beam on are you ?
Also what lens ?
Thanks Peter,
I had the Flash on P-TTL as I had selected trailing curtain sync. I was literally trying everything until I got it, before I know it had to be P-TTL. My camera was on manual, 2.5 secs, f2.8, ISO 400. The lens was the Pentax 16-50 DA* I thought that there were perhaps settings on the camera I had to select to get successful tcs. but I now realise this is not the case. In casting around the menu I found there were more flash options for some exposure modes, which puzzled me. I now don't think, however, that this is relevant to my issue.
Thanks again, John
This won't include the K3III, but might help?
Thank you for this John. I have downloaded the guides and they look well worth reading. I shall learn much. John
Also what lens ?
Thanks Peter,
Thanks again, John
Ok.. Can you post some images which show the overexposure. That may help.
Chesterfield
