Today's Walk in a section of the SW Coastal Path.
Philip
Be well, stay safe.
As a general comment, and it does of course depend on what you wanted, for me these images look under-exposed for what seems to be a bright sunny day.
Philip
Yeah sorry about that, I have rushed them out again, SOOC.
I was in manual and checking for no blown highlights by using liveview, I can't do this through the viewfinder unless I am missing something? so normally I would when not in a rush, check them in RT by increasing exposure to near the max on the histogram/curves etc. to lift the brightness.
However I'm usually rushing them out, but TBH on my monitor they did look quite bright, and I have had this before, where on the mobile they look underexposed, but in this case they did look bright, so is it possible your screen/mobile is "dimmer" ? no disrespect but they look okay IMO, perhaps you are correct.
Thanks for the comments, I am going to have to be more stringent in my post processing and posting, I also seem to have a problem with White balance checking LOL.
Ah well still learning.
Cheers.
Be well, stay safe.
As an example, consider Image 6 which has a lot of bright fluffy clouds. I would expect there to be 'white' tones in them, but there is very little in the right-most quarter of the histogram:
A simple tweak to alter this (moving the white point) gives an image which looks more realistic to me:
[ The images above are from PaintShop Pro.]
Cheers.
Philip
Be well, stay safe.
loadoftripe
Member
loadoftripe
KP and DFA 28 to 105mm WR. All SOOC and hand held, used a CPL.
1. On the path down towards Bovisand Beach;
2. Part of old Fort Bovisand ?
3. Remains of the old Diving/Decompression center and harbour, with the Breakwater in the background.
4.
5. Old and new;
6.
