Today's (very little) brainteaser
Posted 11/07/2016 - 13:39
Switch/dial between two settings?
Barrie - Too Old To Die Young
Posted 11/07/2016 - 16:08
H''mm - could be! Any examples you could suggest?
Posted 11/07/2016 - 16:54
spinno wrote:
On/off
No (said that in first post).
On/off
Posted 11/07/2016 - 16:58
One of the rubber door flaps open
Stan J
Stan J
Posted 11/07/2016 - 17:00
Stan J
Nope!
Stan J
Posted 11/07/2016 - 18:08
Come on!
It was a quick fix, so it must have been "easy" (and don't forget the info I gave in the first post)!
Posted 11/07/2016 - 18:21
you hit the mirror lock up by mistake?
Posted 11/07/2016 - 18:55
Not quite sure how you do that (I know it can be done, but have only done it as part of the routine to clean the sensor).
Posted 11/07/2016 - 19:00
lenscap on?
Posted 11/07/2016 - 19:05
D0n wrote:
lenscap on?
Nothing quite that obvious (don't forget that I was already shooting with the lens that was fitted - 150-500 HSM)!lenscap on?
BTW: I saw someone with (IIRC) a D800 and a Bigma (or something like it), and he stood there all day using that combo - with the lens hood still reversed (it had become a sunny day by that time). Does that tell you something about some of the "opposition"
Come on - give you a few more guesses and then I'll come clean on what happened!
Posted 12/07/2016 - 00:59
dead batteries?
Posted 12/07/2016 - 07:00
Something to do with SR and OS ?
W.London
All going quite well until, quite suddenly, the shutter opened and effectively the camera became unusable. Did all the usual things (switched off & on, batteries out the body and grip for a long time and so on) without any change, so swapped the 150-500 to the old K-5 and carried on shooting.
This morning I got the K-3 out again at home, and the problem was still there but I fixed it in about a minute - so what do you think had happened? (no prizes but a little lesson, at least for me!).
