Tips for using new 360 flash with baby ( 8 months)
link
Reduces shadow and softens the light
Concert photography
I will try with the catchlight this time and then maybe get the Omni for shots at Xmas.
Sharon's: K-x, FA35/2, DA 18-250.Glen's: K10D, DA100 Macro, 55-300, Paragon 500, Silk Pro700 Tripod
It is - and looks crude, but it works quite well
regards
Bernard
I've found that a piece of white plastic (ice cream tub lid) held on the flash gun with a rubber band works well in emergencies.
regards
Bernard
If you're after a quick diffuser, Cigarette papers also work very well, you don't even need the rubber band & they're smaller in you camera bag.
Unused tissues/toilet paper will also work but aren't so convenient.
Eastridge
Member
Bideford, Devon
Having nabbed an Amazon bargin 360 flash first test will be some shots of 8 month old nephew weekend after next.
Clearly I can't tell him to look to a certain side / point re the flash direction so will need a spread of light - from the manual I can use flash on camera + the 360 wirelessly from 'the other side'but there is a danger of double shadows yes?
Also I have a static light as used for video filming that could be used as 'infill'.
I know that to diffuse light some use photo umbrellas, I have seen people both bounce the flash off the inside of a reflective brolly or put the flash behind an opague one to diffuse it.
If anyone can point me to a good tutorial or provide any tips from own experience that would be really helpful.
Thanks,
