Tilt & Shift Lenses
Posted 25/08/2012 - 23:22
There's the SMC Pentax 28mm f3.5 - they are found from time to time but are not cheap.
I'm not sure how much the effect is reduced on APS-C, but in any event there are software solutions in Photoshop that work very well.
Posted 26/08/2012 - 06:46
I know Schnider make one for the K mount, not cheap though. Follow the below link for More info.
https://www.schneideroptics.com/ecommerce/CatalogSubCategoryDisplay.aspx?CID=182...
Fletcher8.
Posted 27/08/2012 - 11:11
Pentax 28/3.5 shift: http://kmp.bdimitrov.de/lenses/primes/wide-angle/K28f3.5-Shift.html
Hartblei Super-Rotator tilt & shift and Arsat (tilt &) shift: http://www.hartblei.com/lenses/general_info.htm
Arax (tilt &) shift: http://araxfoto.com/specials/
Schneider (tilt &) shift: http://www.schneideroptics.com
Lensbaby: http://lensbaby.com/
Furthermore several tilt and/or shift adapters for medium format lenses on PK exist.
Posted 27/08/2012 - 20:12
Unfortunately the various 3rd party offerings are not very wide. If you're after a shift lens for architecture the Pentax is the widest. Unfortunately, 28mm isn't all that wide on APSC although I found it worked very well when you had room, e.g., in a cathedral.
As a result, I invested in a 5x4 LF format set-up instead. Still worked out a fraction of the price of buying the Canon TS lens and a body!
K.
K.
Isle of Skye
I appreciate that they won't be autofocus but all other info would be appreciated.
Thanks.
