Tamron AF 70-300mm LD Di A17 Lens Info Required
jamieallan
Link Posted 06/01/2013 - 17:28
I bought this lens recently as a local purchase off Gumtree. It came with no box, instructions or lens hood. It came with a Jessops UV filter. All for 45.
I've checked the Tamron website and the images of the Pentax fit A17 doesn't match this one. The one on their website shows an AF/MF switch whereas the one I bought has an aperture ring - as per the enclosed image.
Does anyone have any knowledge of this lens - or the manufacturers instructions? I'm particularly interested in why when the macro switch is switched and I've taken an image at 1:2 at the closest focussing distance when the lens barrel is at it's max - the lens barrel will then not retract and you cannot throw the macro switch back to the normal position. You effectively have to focus on a further distant object then the lens barrel retracts and the macro switch can then be moved back to the normal position.
Jamie
Cliff-P
Link Posted 06/01/2013 - 19:06
Hi Jamie,
The lens you have looks exactly like mine, The operation of the macro focusing is correct, On your focus ring you will see a gold band between 0.95 and 1.5 m, If you are focused between those two distances the macro switch will remain locked, focus between 1.5m and infinity and the switch will unlock......simples
I dont think the one on Tamrons site is a Pentax fit looks more like Can/Nik fitting and I think they have the Af/Mf switch.
Cliff.
My Flickr link
Helpful
jamieallan
Link Posted 06/01/2013 - 19:18
Thanks Cliff. Is there an instruction sheet for this lens?
Jamie
Cliff-P
Link Posted 06/01/2013 - 19:26
GOOGLE http://www.tamron-usa.com/assets/pdfs/A17.pdf
Cliff.
My Flickr link
Helpful
bettyswolloks
Link Posted 06/01/2013 - 19:28
For 45 that looks like a bargain!
Mal
Link Posted 06/01/2013 - 19:31
Nothing to ad apart from , take the UV filter off it.
Hardgravity
Link Posted 06/01/2013 - 20:35
I have one of these and find it a super lens.
Although I now tend to use my Tamron 18-250 as a go anywhere lens, this one still comes out when the birds are playing in the back garden.
Cheers, HG
I've some gallerieshere CLICKY LINK! and my PPG entries.
Stuey
Link Posted 06/01/2013 - 21:59
I believe that those are better at the 300mm end than the Sigma 70-300 I have
My Flickr site link
Cliff-P
Link Posted 06/01/2013 - 23:00
I just wish Tamron would bring the VC version out in Pentax fit but the reply to my email to them was basically "Sod off your not having it"
Cliff.
My Flickr link
