Super telephoto zoom recommendation.
CHEERS Vic.
and gives good IQ and closer focusing.
SR helps a lot, but sometimes even framing can be a problem if you're trying to fill the frame with a moving subject.
Whilst a 150-500 might be great for birding on a tripod/beanbag, trying to use one at something like an airshow might be too bulky/heavy to be effective (as you get tired your muscles start to tremble...). For sports a monopod might be a very useful investment.
Whilst IQ is very important, shake kills an image completely, as do mis-framing and focus errors - these are my biggest concerns.
It also depends on what you're shooting and how you'll be displaying the shots (using a shorter lens and cropping might be better if you don't need full-res images).
EDIT - Oh and whichever lens you buy, you'll probably wish you'd bought a longer one
Regards,
John.
Regards,
John.
Just to say my 150-500 is handheld over 95% of the time, and with Sigma OS I've shot regularly at 1/125 sec. Slowest sharp shot being at 1/20 sec https://www.pentaxuser.com/photo/user-11709/fox-37127
Hi Alan,
I'm not suggesting you can't hand hold one, but that there are circumstances where its harder to do so well. Tracking aircraft across the sky with a heavy lens for a prolonged period can be quite heavy going (arms, head, neck). Propellers need a shutter speed of 1/250th or less to show movement.
Obviously it varies person to person, but you should consider how relevant it is to your needs before buying the lens.
John.
55-300 is great, but I've tried it with TC's and it doesn't seem to like them. IQ was poor and focussing dire. The siggy 150-500 is superb, but not very compact!
Obviously it will only work with a TC that suits it and like all
long lenses you need to have good focusing technique. With the
55-300mm it's better set between 10M and INF before you start
and the target is better if it's got good contrast.
The Jessop MC 1.7x Pz/AF TC hardly effects the performance of this
lens and I'll be leaving it on my lens more or less permanently
from now on. It loses 1 to 1.3 stops which can be allowed for by
increasing the ISO.
I've also got the Sigma 150-500m, but it's far too heavy to lug any
distance and the DA*300mm is too restricted to the one view.
See https://www.pentaxuser.com/forum/topic/test---pentax-da-smc-55-300mm-f-4-5-8-ed-...
These two were from a few weeks back when the weather wasn't
as bight as it is today.
Rabbit K-5 400ISO
100% Crop
Blackbird K-5 800ISO
I think knowing the OP's age and level of fitness would help. I'm overweight and in my early fifties.
CHEERS Vic
I can echo these findings exactly!
These are very good Algernon. I've not been able to replicate anything like that with my Kenko 1.5X PZ AF although it works well on my DA*300.
increasing the ISO.
Rabbit K-5 400ISO
100% Crop
The Bigmos (Sigma 150-500, the 'Bigma' is the 50-500) is also brilliant but as others have said not compact or light weight. Fortunatly my muscles are used to carrying to much weight, so I can cope with using it handheld for about half an hour at a time, but it doesn't come out with me very often, while the 55-300 lives in my camera bag (it's significantly lighter than my old F100-300).
I've also tried mirror lenses, which are much lighter, but a pain to focus and lacking in contrast. Since getting the K7 cropping the DA55-300 gives better results than using the mirror, so perhaps it's time I sold it.
Much of the decision will come down to can you manage the weight of the Bigma/Bigmos (or afford them). Try carrying a couple of kilos of sugar/pasta or simialr with you on some typical trips to see how the weight feels.
What's your problem? I'm in my 70's and use my 50-500 on a tripod, on a monopod, and handheld. NO PROBLEM.
CHEERS Vic
Two thumbs up Vic !
If you want reach in Pentax (without paying a fortune for exotic lenses) then the 50-500 is as good as it gets and the weight really isn't an issue on a monopod (if you are shooting wildlife then you need to put up with a certain degree of weight/discomfort, it's all part and parcel of the genre) carried over your shoulder when walking.
You'll get better results on a mono than handheld too. I'd definitely add one of those GBP100 gimbals you can get off EBay - far far better than a ball head. Use a strap too (a Black Rapid copy works great) as redundancy (it's saved my gear more than once).
I've been looking for a lens that's boarder line compact enough to carry around. Of course if Tamron made the 200-500mm for Pentax it would be perfect but they don't. I know one of my choices is the 150-500mm Bigma but I was wondering if anyone had any more suggestions? By compact I mean it still looks like a lens and not a telescope so the FA 250-600 is out and I don't really care about constant aperture. Oh and if anyone even thinks about mentioning mirror lenses...
