Stuck adaptor
Posted 14/04/2014 - 15:41
Funnily enough I was looking for info on various lens mounts after another post here the other day. I came across this site which states that there were actually two different 42mm mounts - the M42 with a 1mm screw thread pitch and the T with a 0.75mm pitch. Is it possible you've got a T lens and an M adaptor or vice versa?
http://rick_oleson.tripod.com/index-99.html
Jamie
Posted 14/04/2014 - 15:53
Interesting Jamie!!
I was not aware of this, so will look into it.
It won't cause me a particular problem if it remails stuck to the lens as I don't have any other M42s and can still mount it on the camera.
Posted 14/04/2014 - 16:11
Same thing happened to me where I could not remove adapter from lens thread but after few attempts i went off. I just used towel to hold the adapter and a bit of force it released.
Posted 14/04/2014 - 16:56
I'm guessing it wasnt made by Pentax?
The genuine article is screwed onto the lens and then both are fitted to the camera in the normal fashion. The lens is then unscrewed from the body; you have temporarily converted the K mount body to M42. You then remove the adapter by pressing the spring and out it pops.
It would be worth remounting it and trying to unscrew it.
Posted 14/04/2014 - 17:54
If you have an old k mount film camera that you are not bothered about remount it on to that and apply brute force. I had quite a bit of bother with cheap adaptors now only use genuine Pentax never had any hassle since
The last one that got stuck had to be removed with a dremmel and a pair of pliers!!
Posted 14/04/2014 - 18:32
I think Geordie is right. The best solution Actually I think You can find information in genuine manual:
1. mount adapter to camera body
2. then mount lens to the adapter
To unmount LENS from camera
1. Unscrew the lens from adapter
2. Unmount the adapter from camera body
Posted 15/04/2014 - 13:14
Many thanks for all this guidance.
The adaptor is a genuine Pentax one. I attached the adaptor to the camera and then screwed in the lens. Whe I unscrewed the lens the adaptor was still attached to it and I could not remove it,
Posted 15/04/2014 - 13:17
IIRC the genuine Pentax adapter has a widget that releases the spring clip (next to the "A" of Asahi) on the K-mount.
Posted 15/04/2014 - 13:20
Posted 15/04/2014 - 14:21
Adapter stuck on lens not body so little catch not solution....
Lurking is shirking.!
Posted 15/04/2014 - 14:33
If it's your only M42 lens then IMO it's best left on the lens. I modified my earliest adapters to keep them om the lens & speed up lens changing.
FWIW T2 threads (42mm X0.75) are sufficently different that the adapter will only go on about one turn maximum. It seems there is also a 42mm x 0.5 size thats been used for some filter threads - I've never seen one of these but came across stepping rings for them, as well as a few listed as 'm42' without specifying the thread which turned out to be T2.
Posted 15/04/2014 - 14:37
That's where these widgets have pins on the other side to unscrew from the back end of the lens.
Posted 15/04/2014 - 17:04
Again many thanks for all your advices. As I said recently it is my only M42 so will just leave it on!!!
Posted 15/04/2014 - 19:20
IF your sole M42 lens is a Takumar or similar it may be that the first ring on the body is set to 'auto' (instead of 'man') which can prevent the adaptor being unscrewed.
Roger.
Roger.
Edinburgh
