Visit MPB Visit MPB Visit MPB
SMC PENTAX-F 1:1.7 50mm vs fixed aperture zoom lens?
dinneenp
Posted 31/08/2010 - 14:29 Link
I have a SMC PENTAX-F 1:1.7 50mm lens, find the length too long.
Thinking of swapping for a fixed aperture (2.8 probably) zoom (Sigma 17-70, Tarmon 17-50 or similar).
Pluses- zoom.
Minuses-physical size & weight, aperture.
What do you think, which would you prefer etc?
cheers,
pa.
Cheers,
Pa
Paul_C
Posted 31/08/2010 - 17:34 Link
I find the 50mm on a crop sensor dslr is a bit long , good for portraits.
I have the sigma 17-70mm f2.8-4.5 and find it a great range for a walk about lens.
I rarely find my self needing anything any wider than 17mm or longer than 70mm, wish it was a bit faster for low light stuff but then it would cost alot more.
Modern zooms are very good , i've been very impressed with both the Pentax 18-55mm wr and the Sigma 17-70mm
thoughton
Posted 01/09/2010 - 14:41 Link
I have the Tamron 17-50 which has performed very well for me. Colours are perhaps a tad cooler than Pentax lenses, but it's nice and sharp. Pretty good wide open up to maximum sharpness at around f5.6.
Tim
FlickrFluidrPPGStreetPortfolio site
flat4
Posted 01/09/2010 - 15:39 Link
dinneenp wrote:
Pluses- zoom.
cheers,
pa.
Sigma 17-50/2.8 has a fixed aperture, 17-70 doesn't. I guess it's very much up to your style of photographing. Personally, I would keep the fifty even if I bought a fast zoom lens.
Link to my PPG
Mannesty
Posted 01/09/2010 - 15:47 Link
I can't comment on either of these lenses because I have no experience of them.
What I do know however is that they are not known as 'fixed aperture' lenses. The correct term is 'constant aperture', that is if the lens is set to f11 at one extreme of it's zoom range, it will remain at f11 throught the entire range.
The term 'fixed aperture' applies to lenses like the various 500mm mirror lenses which have their aperture fixed at f8, or similar, and can only be changed by the addition of ND filters.
BTW: The SMC Pentax DA* 16-50mm 1:2.8 lens is a constant aperture zoom lens and produces excellent results.
bforbes
Posted 01/09/2010 - 15:48 Link
Do Tamron do their 17-50 in a Pentax mount?
davex
Posted 01/09/2010 - 16:37 Link
Yes, it wasn`t hard to find.
My flickr: link
flat4
Posted 01/09/2010 - 16:47 Link
Mannesty, you are correct. The correct term is constant aperture. Fixed aperture would be in a case of mirror lens.
Link to my PPG
Anvh
Posted 01/09/2010 - 23:45 Link
Peter I'm having troubles to understand how a ND filter can alter the aperture, could you please enlighten me?
Stefan
K10D, K5
AF-540FGZ
Anvh
Posted 01/09/2010 - 23:48 Link
For quite sometimes as far as I know
Sigma also has now a 17-50 f/2.8 EX OS HSM for Pentax link
Here is a review link
Was thinking about getting that one instead of the DA*16-50 but the Sigma wasn't out yet but IQ wise the Sigma has the same weak wide open at wide focal length preformance so not disappointed I didn't wait for it.
Stefan
K10D, K5
AF-540FGZ
Edited by Anvh: 01/09/2010 - 23:57
flat4
Posted 02/09/2010 - 05:45 Link
I think he means that by adding ND filters you can lower the amount of light passing through the lens, i.e. "changing the f value".
Link to my PPG
Edited by flat4: 02/09/2010 - 05:46
Mannesty
Posted 02/09/2010 - 08:38 Link
Exactly right. Some mirror lenses are supplied with ND filters for this purpose from new.
Technically the aperture doesn't change of course, but the effect of adding an ND filter is to attenuate the light in bright conditions. Bokeh and DOF remain unchanged.
Edited by Mannesty: 02/09/2010 - 08:42
Anvh
Posted 02/09/2010 - 17:51 Link
Thank you Peter to enlighten that bit, I was under the impression you meant it changed the f-ratio and therefore also the DOF.
Are there any ways to control the aperture with mirror lenses?
Stefan
K10D, K5
AF-540FGZ
Posted 02/09/2010 - 18:00 Link
No, the aperture is fixed. However, because of the zooming the aperture of the Pentax 400-600mm does change.
Anvh
Posted 02/09/2010 - 18:26 Link
Aren't there ways to make the opening smaller like a diaphragm does, maybe in form off a filter or will that give vignetting?
Just a little point, do you really mean aperture or the f-number?
Those are two different things and one change with zooming alone but the other needs physical changing so I'm not sure which you mean.
Edit: make a mistake myself.
Stefan
K10D, K5
AF-540FGZ
Edited by Anvh: 02/09/2010 - 18:31
