Shooting RAW and JPEG at same time K5iis
Phil
My Flikr Page link
(Janis Joplin)
KIT: K5iis, DAWR18-55mm,FA4.5 80-320mm, Mitsuki 5.6 400mm, M1.7 50mm, M1.4 50mm, M2.8 28mm, Miranda M2.8 28mm, M3.5 135mm, M1.4 200mm, Vivitar S13.5 70-210mm, Vivitar A 2.8 90mm macro,
Sigma150-500mm F5-6.3 APO DG HSM.
There's a RAW button also on the front of the camera, near where the lens attaches, and this can be configured in the custom menu to control the RAW / RAW pus option with a single press.
Just open the RAW in Faststone Image Viewer and then save the image which opens first (it's the JPG). TO access the RAW in Faststone simply press 'A" after the JPG loads.
The reason there's an embedded JPG is for the camera preview (and zoom when you're chimping) It's not an inferior version of a JPG either. Depending on the camera model (and your JPG settings) it will either be the exact same resolution or very slightly smaller.
There's also another free utility which you might like to try called Instant JPEG From RAW
Instant Jpeg From Raw (IJFR) is a Windows® and Macintosh® utility that extracts the native JPEG image that is embedded in RAW files. The utility is available
from your cursor’s context-sensitive menu by right-clicking (or Ctrl-clicking on a Mac) anytime a Raw file is selected on your PC.
Get it here:
► http://michaeltapesdesign.com/instant-jpeg-from-raw.html
It's been around for many years, always surprises me how so many people don't know about the embedded JPGs in RAW.
Watch the video:
► https://www.youtube.com/watch?v=u89zSlb_PwM
Note: I've used this method with every Pentax DLSR I've had since 2004. I still use it with my Olympus OM-Ds and PEN.
I wonder because my K7 RAW files are usually around 12-15mb ..... But my max quality JPEGs are around 7-10mb! Could a JPEG even approaching this quality possibly be buried within the RAW file as well .... Surely if it was I'd be looking at RAW files more like 18-20mb ... ?
But could there really be a decent sized JPEG saved within the RAW?
Yes.
In the case of my K-7 DNG or PEF files the resolution is different by only a few pixels;
RAW 4684 x 3122 embedded JPG 4672 x 3104
Yes.. But using FASTSTONE or IJFR you save the JPG using whatever compression ratio you choose. I always choose 80% IQ, but you may choose 100% IQ if you like bigger data (more megabytes) without any visible advantage.
Confirm the differences by saving out the embedded jpegs.
It can still be worth saving both raw+jpeg as some software cannot render the raw files so without processing you wouldn't know what the image was. It also gives a duplicate in case the image gets malformed in the camera. (Can happen if you switch the camera off while images are still in the buffer, so I've found.)
To be doubly sure I take raw+jpeg in both slots now. Just because you have four images doesn't mean you have to keep them all, but helps to ensure you have at least one in case a card goes bad.
I'll try that on my other brands as well. Not that I'll use the extracted JPEG for anything.
It's a can of worms John.
Ha, you're just cherry picking there
I suggest more research. There is plenty of legit information on the web. Facts are facts, they are easily found and tested rather than posting screenshots from random posters pretending they are pasting replies from camera a company email
Look chaps, I'm not going to argue with anyone about it, I have nothing to prove. You can do you own research and experimentation then come to you own conclusions and beliefs. It make zero difference to my years of experience.
I posted about JPEG from RAW for the benefit of the OP but if it helps others then all all the better.
Have a great weekend!
10 years
Taynuilt,
Argyll,
UK.
(Janis Joplin)
