Shake reduction and focal length
Posted 01/10/2011 - 22:02
That's a very good question. I haven't got a clue.
Posted 01/10/2011 - 22:02 - Helpful Comment
Froggy wrote:
If,say, I put a 50mm A series lense on my K5 and I input the focal length for the purposes of shake reduction, what do I input? Should it be 50mm or the digital sensor equivalent of 75mm?
50mm.If,say, I put a 50mm A series lense on my K5 and I input the focal length for the purposes of shake reduction, what do I input? Should it be 50mm or the digital sensor equivalent of 75mm?
Always the actual focal length.
The focal length of a lens doesn't change just because the sensor happens to crop a smaller rectangle out of the image circle than a 35mm negative does.
Think about the amount the image moves because of the shake. The size of the sensor doesn't affect it, so the amount the sensor needs to be moved to compensate is not related to its size.
Posted 01/10/2011 - 22:09
How does this change when you add Extension Tubes or a Teleconverter? I was using a 135mm SMC Takumar (M42 with adaptor) coupled to 68mm of Extension Tubes. What focal length should be input for this? It's still a 135mm lens, but is now 68mm further from the sensor. This must surely affect the calculation?
Posted 02/10/2011 - 05:56 - Helpful Comment
Focal length is focal length; it does not change when you put it on an APSc camera
Posted 02/10/2011 - 06:08
One post I found in http://www.flickr.com/groups/closer_and_closer/discuss/72157604389806550/ clearly states that focal length does not change with extension tubes. You might want to do some more research to get this confirmed by a second source (I don't have the knowledge about this).How does this change when you add Extension Tubes or a Teleconverter? I was using a 135mm SMC Takumar (M42 with adaptor) coupled to 68mm of Extension Tubes. What focal length should be input for this? It's still a 135mm lens, but is now 68mm further from the sensor. This must surely affect the calculation?
I do think that the point is not really relevant because you more than likely use a tripod and have SR switched of in that case
Posted 02/10/2011 - 21:36
But surely the SR requires a focal length input only to calculate the approx magnification and hence the shake? This would be more with extension tubes, teleconverters etc so why isn't more SR needed in the algorithm calculation when they are added?
Dave
Dave
Posted 02/10/2011 - 22:01
I also use the lens focal length with extension tubes, with the 2 x converter 2 x lens focal length and 3 x converter 3 x lens focal length.
Posted 02/10/2011 - 22:59
For teleconverters, yes, more SR is needed, since they make the lens magnify more. For extension tubes, no, more is not needed, since they don't.But surely the SR requires a focal length input only to calculate the approx magnification and hence the shake? This would be more with extension tubes, teleconverters etc so why isn't more SR needed in the algorithm calculation when they are added?
The thing is, if you use a longer focal length lens (or a teleconverter, which amounts to the same thing), you get extra magnification at the same distance from the subject.
If you use extension tubes, the only reason you get extra magnification is because you move the camera closer to the subject. Focusing is the moving of the lens along its axis towards or away from where you want the image to be in focus. Extension tubes do nothing except help you move the lens further away.
It's the same with macro lenses - they're macro lenses because they allow close focusing, not because they have a different focal length than a non-macro lens.
You dial in more SR with longer focal length lenses because they magnify more than shorter focal length lenses. So for a given angular displacement of the camera (read shake), the image on the sensor moves more than with the shorter lens, and hence needs more correction.
The lens with an extension tube is not magnifying more in the same sense. The image is bigger only because you're closer - there's no extra magnification. So for a given angular displacement, the amount the image moves is the same, so needs the same correction.
Posted 02/10/2011 - 23:15
Mike-P wrote:
I always dial in 500mm when I use the A* 300mm f2.8 and Pentax 1.7x teleconverter (hand held). With extension tubes I use the lens focal length.
What happens if you use the 1.7x TC with an AF lens?I always dial in 500mm when I use the A* 300mm f2.8 and Pentax 1.7x teleconverter (hand held). With extension tubes I use the lens focal length.
Does it figure out the amount of SR automatically, or does it prompt you to tell it the way it does for a MF lens?
Posted 03/10/2011 - 00:08
[quote:3496ace15f="sterretje[/quote]One post I found in http://www.flickr.com/groups/closer_and_closer/discuss/72157604389806550/ clearly states that focal length does not change with extension tubes. You might want to do some more research to get this confirmed by a second source (I don't have the knowledge about this).
I do think that the point is not really relevant because you more than likely use a tripod and have SR switched of in that case [/quote]I almost never use a tripod with the tubes attached as I find it very restrictive. OK, if it's a static subject then the tripod may be used, but almost always the subject is moving if only becuase the wind is blowing. Therefore, the SR setting is fairly important to me.
Posted 03/10/2011 - 13:43
It asks for the focal length.Does it figure out the amount of SR automatically, or does it prompt you to tell it the way it does for a MF lens?
Pentax are a bit annoying in that respect, every tc I have tried bar the 1.7x does not report the extra focal length or aperture (and the 1.7x only does because you dial it in). With the Canon I put the Sigma 1.4x onto a 100-300mm f4 and everything in the exif is correct.
Posted 04/10/2011 - 13:42
Yes, that seems to make very good sense.
Dave
Posted 04/10/2011 - 23:21
Theory on this sort of thing goes round in circles Why not try both and see which works best?
Lancashire
