Seized battery cover Pentax MX
cabstar
Posted 21/08/2018 - 23:26 Link
Hi
I have seized up battery cover on my MX any tips on how to remove it???
Concert photography
bforbes
Posted 22/08/2018 - 00:54 Link
If you removed the base plate would the cover come with it? It might make it easier to work on releasing it.
johnha
Posted 22/08/2018 - 01:49 Link
I have a seized Spotmatic battery cover (I think there's a leaked battery in there), in the case of the Spotmatic, the whole battery enclosure, including the cover is part of the baseplate. I've tried coke & WD40 (but have given the boiling oil trick a miss!). I have a spare baseplate which would fix the issue if I had another battery cover (but they're ££ on eBay). My next plan is to try and freeze just the cover - hoping it will contract and 'crack' any battery gunge in there - quite how I can do that is a different question.
My MX battery cover has two holes in the coin slot about 1cm apart (similar to those on the wind lever hub) - maybe there's a tool allowing more leverage than a coin would allow (the current 5p is my preferred implement)?
danofmk
Posted 22/08/2018 - 07:34 Link
Best off just buying a spotmatic for parts than just the battery cover. Will probably cost about the same. Keep the rest of it for parts or just list it again for parts....
danofmk
Posted 22/08/2018 - 07:35 - Helpful Comment Link
Meant to say I've got an mx for parts, so if you need anything just let me know
Think I've got a complete base plate and battery cover
Emphasis on think.
Will check when I've got a second
cabstar
Posted 22/08/2018 - 07:57 Link
The baseplate screws have rounded off looks like the previous owner has given it a go already grrr
Concert photography
cabstar
Emphasis on think.
How much would you want for baseplate and screws too please?
Concert photography
Jonathan-Mac
Posted 22/08/2018 - 08:00 Link
I think I read somewhere that soaking in vinegar can un-stick battery covers glued in place by leaked battery gunk.
danofmk
Posted 22/08/2018 - 09:49 Link
Assuming I've got it you're welcome to it gratis
Will check tonight
Posted 22/08/2018 - 14:28 Link
I have found that a 1p coin is better than a 5p coin as it has sharper edges that give more grip.
danofmk
Posted 22/08/2018 - 14:46 Link
I've got a Danish krone that's slightly bigger than a 5p, so easier to grip and if my a level physics is up to scratch, more torque too!
johnha
Posted 22/08/2018 - 16:29 Link
I prefer the thickness of the 5p, less likely to slip I feel.
The MX service manual is available here link - looks very complicated but the exploded diagram shows the baseplate/battery compartment quite well.
danofmk
Posted 22/08/2018 - 21:12 Link
Just checked, all present and correct so if you pm me your address I'll get it sent
jeffstclair
Posted 13/09/2018 - 16:04 Link
I have found for this sort of job a washer and a small aj does the trick .....gently gently ....jeff...
