SDM Problem with DA* 50-135mm
Posted 14/09/2021 - 20:49
It's not terminal as both my 50-135mm and 16-50mm have done the same thing for years.
I have found (on the K-1 at least) that they wake up a lot quicker if you use liveview first. Alternative is to change them over to screw drive with a hack available on Pentaxforums.
Posted 14/09/2021 - 20:56
Yes, my old 16-50 was notorious for this. My method was to have AF on, half press the shutter and manually turn the focus ring (quick-shift) to and from the extremes a few times. Lens would eventually wake up.
It went on for years like this and never failed entirely.
Posted 14/09/2021 - 23:20
Yes, as above, rotate the focus ring through the whole range with the AF button pressed and the lens cap on.
Option 2 is to convert to screwdrive.
Option 3 is to remove the mount and rotate the motor manually with a screwdriver. This might have the effect of loosening the grease in the unit (theory)
All the gear with no idea
Posted 15/09/2021 - 07:08
Option 4 is you've a good reason according to Mike-P to purchase a K1 LOL
Chris
Posted 15/09/2021 - 09:29 - Helpful Comment
Both my 16-50 and 60-250 went from working well to not working at all, there was never a grey phase. My recently departed DA300 was no problem.
I have heard from multiple sources that a seemingly failing lens can be given a burst of life through intense use and correct storage. Alas, I went from fully working lens to dead lens and another cheque for £150-180.
Z-1p, K-1, P50
Posted 15/09/2021 - 11:36
The 17-70 was another lens that was supposed to be immune to SDM failure but the one I tested at Jessops in Richmond failed out of the box - I was looking at it when my 16-50 was at Johnson's... the 17-70 IIRC was only SDM and had no screw-drive option.
I did try the 50-135, but as I had the Sigma twins at the time thought the 60-250 would be the better replacement for those. It was nice, the guy who owned the 50-135 was inquisitive about my 85*. so we had a sway for a day.
Z-1p, K-1, P50
Posted 15/09/2021 - 17:17
Thanks for your suggestions - I'll try them all before I consider reverting to screwdriver!
Lots of gear - but not a lot of idea!
Posted 15/09/2021 - 19:25
malfis wrote:
I think buying a K-1 is a bit overkill tbh.
Thanks for your suggestions - I'll try them all before I consider reverting to screwdriver!Yes, as above, rotate the focus ring through the whole range with the AF button pressed and the lens cap on.
Posted 15/09/2021 - 19:44
Sounds like an excellent excuse to me...
Posted 15/09/2021 - 19:56
Only a very little bit
Kineton,
Warwickshire.
Whenever I try to use the above lens for the first time on any particular day it takes me ages to ‘wake up’ the SDM by constantly switching the camera on and off and trying to activate the autofocus.
Is it easily solvable or does it mean it’s a terminal problem with the lens, and if so approximately how much does a replacement SDM cost?
I’m loathe to ditch the lens as it’s a super copy.
Thank you.
