SDM Failure
Posted 07/01/2018 - 17:01
I had my suspicions this problem had never been addressed.
Sorry to hear you've got the SDM failure problem. I sent mine to Johnsons Photopia Ltd, the official UK Pentax service centre. 2-3 years ago it cost me about £180.00
Posted 07/01/2018 - 17:25
Don't forget Pentax User Plus members get 20% discount on servicing from JPS. Well worth the modest cost.
Posted 07/01/2018 - 17:29
Alternatively, you will be able to convert it to screwdrive so you can still use it. The AF with screwdrive is just as fast if not faster, and not all that loud.
All the gear with no idea
Posted 07/01/2018 - 17:33
Is this easy to do? If so, how do I do it?Alternatively, you will be able to convert it to screwdrive so you can still use it. The AF with screwdrive is just as fast if not faster, and not all that loud.
Phil
My Flikr Page link
My Flikr Page link
Posted 07/01/2018 - 18:01
swarf wrote:
Phil
Phil
link
link
link
link
link
link
link
Regards, Tom
K-1ii,K-3iii's.
SMC PENTAX-F 1:2.8 28mm, HD Pentax-D FA* 1:1.4 50mm SDM AW,
SMC PENTAX-D FA MACRO 1:2.8 100mm WR,
SMC PENTAX-DA* 1:4 300mm ED [IF] SDM,
SMC PENTAX-FA* 1:4 600mm IF & ED,
HD PENTAX -DA 1.4x AW AF REAR CONVERTER,
Pentax Photo Gallery
K-1ii,K-3iii's.
Posted 07/01/2018 - 19:45
I recommend Asahi Photo in Brentford (speak to Pramath), they do it at a fraction of the cost of JPSS.
He said that replacement units are unreliable, he does test them before fitting. My 16-50 is on its third motor
AKA Welshwizard/PWynneJ
Posted 08/01/2018 - 02:00
The various postings relating to failed SDM components have led me to avoid them like the plague. If they are that unreliable, why do Pentax keep selling them?
Posted 08/01/2018 - 06:55
Unfortunately, until Pentax release a revised version of the lens, the best solution is to buy a Sigma or Tamron 17-50mm f/2.8 instead.
I wouldn't touch any SDM lenses with a barge pole, even though the WR would be really handy.
Posted 08/01/2018 - 08:41
This stems from some early problems with a design fault in a couple of SDM lenses and it was tackled years ago by Pentax. There will always be some failures of any item, but SDM should be as fine as any other focusing system motor. WE haven't heard much about the issue for a very long time.
Posted 08/01/2018 - 08:55
Swarf’s lens is only three years old, so unless it was old stock it sounds as if the issue hasn’t been fully sorted yet.This stems from some early problems with a design fault in a couple of SDM lenses and it was tackled years ago by Pentax. There will always be some failures of any item, but SDM should be as fine as any other focusing system motor. WE haven't heard much about the issue for a very long time.
I am concerned because I am thinking of a DA*200mm lens.
Posted 08/01/2018 - 09:32
The point I'm making Rob is that Swarf's lens could be the only one that's failed in the last three years, we have no idea what the percentage failure rate is.
There has been no history of problems with the 200mm f/2.8 lens.
Posted 08/01/2018 - 09:36
Thanks for the reassurance John.
Posted 08/01/2018 - 09:59
The SDM on my 16-50 failed and had to be replaced. Even with the new motor it soon became sleepy and I lost confidence in it and traded it in for a 20-40. However, my other SDM lenses - DA* 200, DA* 60-250 and DFA 24-70 - have never given any problems. I suspect the design of the 16-50 makes greater demands on the motor. The DA*200 is a great lens. I don't think you will be disappointed.
Regards, Philip
Posted 08/01/2018 - 13:47
Got mine new about April last year
Modest amount of use but doing very nicely for me so far.
Will say if that changes mind!
Woking
If not, where's the best place to get it repaired, and any ideas on how much it might cost?
Phil
My Flikr Page link
