SD card recommendations
Posted 10/05/2018 - 21:52
I run with 32Gb Sandisk Extreme cards rated at 60MB/S which is better than the cameras can run at. So far so good. Not sure on current prices but there's plenty of other good brand cards out there.
Posted 10/05/2018 - 22:40
SanDisk extreme pro up to 95mb write speed. Never had one fail me yet and very reasonably priced these days.
Did consider purchasing faster but I believe the Pentax range can't write any faster so would be a bit pointless.
Hope this helps.
Hope this helps.
Posted 10/05/2018 - 22:54
Hope this helps.
This.SanDisk extreme pro up to 95mb write speed. Never had one fail me yet and very reasonably priced these days.
Hope this helps.
I use solely SanDisk 90 or 95 extreme/pro cards and swear by them.
I always format in camera, and remove the SD card from the camera to copy to a computer afterwards.
Posted 10/05/2018 - 23:08
Until recently I only used San Disk but I have now got a Samsung. Its seems to be of good quality and is supposed to be water proof + more - see in description.
https://www.amazon.co.uk/gp/product/B06XFBGYLW/ref=oh_aui_detailpage_o00_s00?ie=UTF8&psc=1
Posted 10/05/2018 - 23:10
Sandisk Extreme Pro for me 95 mb/s write in my K3II. I have had one fail replaced by Amazon no quibble.First ever failure since going digital in 2002.
If a card plays up, dump it before you lose something important. Flash is a volatile memory format.
I have some Toshiba 30 mb/s cards that seem to work fine too.
Both XD SC! as noted on the card door.
I too format after each days downloading via the card reader on my PC.
Posted 10/05/2018 - 23:44
Extreme Pro or equivalent. I am a bit blase about card unless both cards fail simultaneously.
Sandisk Extreme Pro 32mb 95 mb/sec are insanely cheap these days, I paid £15-20 for the last ones I bought at Focus/Societies. Even on K-1 it takes a long time to fill slot 1 with RAWS.
I always shoot RAW slot 1 JPEG slot 2.
AKA Welshwizard/PWynneJ
Posted 10/05/2018 - 23:53
I can vouch for the aftersales service on Sandisk cards. After I has a problem with the plastic housings diminishing and cracking. In my K5II On 6 separate cards All were replaced under warranty. even though they were 6 years old... No Issues with the K1 I'm happy to say..
I too use the 95Mb/s Extreme cards 32 and 64 Gig.. But would also give a thumbs up to Transend..
Stuart..
Stuart..
Posted 11/05/2018 - 00:02
I have been using SanDisk Ultra 16GB cards for a long time. I download via the USB cable and don't do anything to the cards except fill them up. Then I label each one with the date (from/to). That way the card doesn't get overwritten and serves as a hard copy backup. They are relatively inexpensive so I can't see the point of removing it to a card reader every day, reformatting it and otherwise doing things to promote problems.
Posted 11/05/2018 - 11:39
Thanks everyone. I have Sandisk cards at the moment, and have just ordered a new one.
The old one is probably fine. Just lately, however, it has taken several attempts to get the slot on my laptop to recognise it, whereas it recognises the second SD immediately. Rather being safe than sorry, I thought it best to replace it. I'll add the old one to the pile I keep in case I fill my primary ones, but I haven't ever filled 64gb of card memory before I have a chance to download!
Cheers, Kris.
Cheers, Kris.
Posted 11/05/2018 - 12:07
Hi Kris,
Depending on what card you have, you may be able to claim on warranty?
https://www.sandisk.co.uk/about/legal/warranty/warranty-table
Posted 12/05/2018 - 15:01
AlJones2402 wrote:
Hi Kris,
After three years and quite a bit of use, I think I got my money's worth. The new card arrived this morning. It has noticeably faster writing speed than the old one so all's good.Hi Kris,
Thanks everyone. K.
Posted 12/05/2018 - 22:18
Used the K-1 today and on copying the files from the cards to hard drive noticed they were both Sandisk Extreme 64Gb 90Mb. I thought I only had 32Gb cards. Must be old age kicking in.
Posted 15/06/2018 - 11:34
Benefit of the faster cards is clearing the internal buffer as quickly as possible.
Hertfordshire,
mostly.
Any recommendations as to good / fast / reliable SD cards? I'm afraid my knowledge of all the classes etc. is close to non-existant!
Thanks, Kris.
