Scratches on front glass - an issue?
RyanK
Posted 01/08/2012 - 07:29 Link
Hi
I've found a lens that i'm really interested in. Gets great reviews and is difficult to find.
The seller describes it as beeing in good shape cosmetically and optically no issues. Only thing that is holding me back is a small scratch on the front glass
Should this worry me? Is it likely to have any influence on the photos taken?
Ryan
Pentaxophile
Posted 01/08/2012 - 07:43 Link
Shouldn't have an impact, but you should expect to pay slightly less than a perfect sample.
geordie01
Posted 01/08/2012 - 08:00 Link
I have a lens with scratch on the front element and it has no effect at all on the image.
greynolds999
Posted 01/08/2012 - 08:32 Link
It might seem odd but a single large scratch is rarely an issue. Multiple small scratches are far worse.
Is this from a store or a private seller. Most shops will allow you to check it and send it back if you don't like it.
Hardgravity
Posted 01/08/2012 - 08:52 Link
I'm with Greynolds on this.
If you can try it out then do so. A few scratches should be OK,but if it looks like it's been cleaned with a Brillo pad...
Cheers, HG
PPG entries.
Mike-P
Posted 01/08/2012 - 08:53 Link
I recently sold a Sigma 70-200mm f2.8 on another forum (Canon fit) which had quite a deep scratch on the front element along with a couple of other smaller marks. It was absolutely fine, of course it was priced well below a perfect example but the buyer was more than happy with the pictures it produced.
ilovesaabs
Posted 01/08/2012 - 09:10 Link
it's not the FA*200 Macro is it Ryan?
I guess you've seen the scratch for yourself - I guess the most important thing is where in the field of view it is, off-centre I hope, then it should be ok, but if it was central I'd be a little bit wary. Until we can see we can't really judge.
I see you're from Herning - was there for an NSU-Treffen (gathering) last June, went into town - very nice indeed and spent a day in Ribe too.
AKA Welshwizard/PWynneJ
Mike-P
Posted 01/08/2012 - 09:15 Link
Hmmm, if it's a macro then that's a little different.
The apertures you shoot with macro means the mark is more likely to show up in pictures so size and depth of the scratch could be important.
Algernon
Posted 01/08/2012 - 09:37 Link
Any scratches on the front element are exactly the same
as having a Starburst Filter.... if you had a cross for
example any light points would have a star radiating
from them.
A single scratch if it's wide and long will produce a line
right across the frame at any bright points, which could
also be reflections caused by a flashgun. You have
absolutely no control over it.
If it's bad I wouldn't touch it with a bargepole
RyanK
Posted 01/08/2012 - 12:12 Link
Thank you all.
The scratch is rather small and superficial, localized peripherically.
The lens in question is a K 28 f3.5 and I think I may give it a chance.
What would a fair price be?
Frogherder
Posted 01/08/2012 - 12:28 Link
I used to have a film SLR with a 55mm lens which had a cracked front element.
Looked horrendous, but appeared to have no effect on prints that anyone ever noticed.
regards
Bernard
Mannesty
Posted 03/08/2012 - 21:16 Link
A scratch on the front element might produce a bit more flare than usual in certain circumstances.
If the scratch is significant enough, you can paint out the scratch with a black marker, black mascara, Matt black paint or similar to reduce/eliminate it.
By doing this, essentially you are filling the scratch with a non reflective material.
It's an old trick, but works.
This lens (in this condition). . . .
produced this image . . .
Edited by Mannesty: 03/08/2012 - 21:26
Frogherder
Posted 03/08/2012 - 22:49 Link
Mine was nowhere near that bad. It had a dink on the filter thread which produced a single crack, straight acros the middle. So I think I got off lightly.
Do you get any funny looks when you turn up with that lens (I used to)
regards
Bernard
Edited by Frogherder: 03/08/2012 - 22:50
Mannesty
Posted 03/08/2012 - 23:00 Link
regards
Bernard
It's not my lens. I found links to these images in an internet article on the subject of scratched/cracked/chipped lenses.
Frogfish
Posted 04/08/2012 - 07:08 Link
Haha Peter - I was going to link to it. It's an article from Lens Rental in the USA. Produces amazing flare
