Scotland Panoramics
abam48
Posted 18/09/2012 - 09:22 Link
Hi all,
Recently posted a panoramic I took while on a charity hike earlier this year ("Breathtaking"). Here is another one that I did but I have several versions and would like people's opinions on which they prefer.
There are 4 versions of the same image:
1) HDR version
2) Tonal contrast adjusted
3) B&W conversion
4) As shot (no PP)
Thanks in advance for and comments and opinions
kingfisher
Posted 18/09/2012 - 10:05 Link
beautiful scenery, rough...it reminds me torridon area which I visited 3 years ago....unfortunately the weather then was rubbish so I didn't take any photos
I like the last one most
stub
Posted 18/09/2012 - 10:17 Link
The original one for me is the strongest..
Stuart..
giofi
Posted 18/09/2012 - 17:43 Link
The original for me as well
greynolds999
Posted 18/09/2012 - 18:01 Link
#1 is the best but for me it is overcooked. I think you need to get somewhere between #1 and #2.
davidstorm
Posted 18/09/2012 - 21:01 Link
For me, the original is the best of the bunch. I'm not sure what settings were used, but to me they all look a little flat and lacking in colour / dynamic range. Are they a bit under-exposed?
abam48
Posted 18/09/2012 - 22:27 Link
Good spot - It is in Torridon - the watercourse seen in the image is in fact the River Torridon
abam48
Posted 18/09/2012 - 22:31 Link
Thanks David - similar to the previous upload this is composed of 8 individual shots that I've stitched. I think I shot them on Aperture Priority at f/14 or f/16. I think they are all a little underexposed to be honest because the natural light was pretty rough because the weather was so changeable throughout the day.
What would be the easiest way to improve the dynamic range that you would suggest?
davidstorm
Posted 18/09/2012 - 22:38 Link
Hi Adam, there are probably a few things you could do:
- Shoot at a wider aperture; you don't need F14 or F16 for this type of shot unless you have very close objects that need to be pin-sharp. On a wide-ish lens you'll find that F7.1 or F8 is usually ample and this will help keep the ISO low - the lower the ISO the greater the dynamic range you can squeeze out, also your lens will perform better at F8
- Have you adjusted the levels to maximise the range?
- Did you use a ND Grad filter? A quality one will always help to balance bright skies and darker ground - take a look at PUMA's images and you will see what I mean
- A polariser will sometimes help, but the light probably needs to be a bit better than you had
Best wishes
Edited by davidstorm: 18/09/2012 - 22:39
Stuey
Posted 19/09/2012 - 12:40 Link
I have to agree that somewhere between 1 and 2 would be my preference
My Flickr site link
greynolds999
Posted 19/09/2012 - 12:42 Link
I think that to get this to work properly you need to apply different settings to different parts of the scene. Which is a lot of work.
The clouds in #1 are spot on but the rest for me is overdone.
Copy the clouds to a new layer and hide it. Then do your adjustments to get the rest of the scene right (for me between #1 and #2) and finally put the clouds back in.
At least that's the theory. With my PS skills, it would take at least an hour!
tyronet2000
Posted 19/09/2012 - 13:12 Link
I like #4 but would like to see the results of the suggestions you have been given regarding the images. I think #3 seems to have lost some of the contrast between foreground and background.
Stan
