Samyang T-S 24mm F3.5 ED AS UMC Tilt/Shift
Let me know what you come up with if you decide to make the trip
I found this link which does seem to confirm that the overhang could be an issue https://www.dpreview.com/forums/thread/4003428
Thanks, that at least answers my queries. At least the lens can be fitted on the mount, and a vertical shift reduction from 12 to 10mm (with a bit of tape to stop marking the K1) is probably liveable with. I cannot see a circumstance where I would use the shift at 45 degrees, and if I wanted the full 12mm shift I could turn to portrait mode.
The usual uninformed comments in the article criticising Pentax on the design compared to the other makes but I wonder whether any other bodies have the same issue - as I said before I saw a video where the shift appeared to touch a Nikon overhang. I see the Canon and Nikon TS lenses have a bit more length between the mount and TS mechanism so maybe this a problem of Samyang’s making rather than Pentax.
You may wonder why bother when vertical distortion can be rectified in post production? I agree where this is very minor but otherwise there are two issues: firstly the more you correct the greater amount is lost through cropping, and secondly the image gets degraded in quality as before and after checks will show. Shifting horizontally can also improve the viewpoint if you cannot physically stand in the ideal spot. And finally, the tilt allows you to change the depth of field close to the camera so will be interesting to see what happens when a macro filter is attached, maybe avoid the need for focus stacking?
Trouble is, the siren call of Black Friday deals is seducing me to one of the lenses on offer this week so maybe the Samyang will have to wait.
It would probably be best to buy the Samyang lens and return it if it doesn't work as needed, or if possible go and visit a shop that has it in stock. The latter might be more difficult.
I presume you realise that in liveview the sensor can be shifted to use a normal lens 'shifted' !
If you've got any sample images on the K-1, they'll be interesting to see.
If I ever come across a really pristine copy of the Pentax lens I might be tempted, although I am a bit of an obsessive when it comes to condition so a long shot. As Canon and Nikon produce a range of pro quality shift lenses it would be nice if Pentax followed suit with at least one update.
What do you make of the Pentax shift lens, John?
Those buildings are very close so it would normally be hard/impossible to get them fully in the frame without them leaning backwards.
All HDR'd as it was very flat lighting. The lens is fine and gives more scope for shifting than the K-1's sensor shift allows. It isn't a lens I'd normally carry unless was anticipating needing it. Nice to have in the arsenal though.
Thank you, those are some very interesting images (the second pic demonstrates the shift impressively well). I don't have any express need for a shift lens but there's a certain itch at the back of my brain for stuff like this
It’s called gear acquisition syndrome! Know how it feels.
9 years
Warwickshire
Bearing in mind the problem with Sigma lenses rubbing against the K1 I am concerned that this could be similar - has anyone tried this combination?
