Samyang/Falcon/Rokinon/Vivitar/Bower 85mm f1.4
robbie_d
Link Posted 05/02/2010 - 15:59
Has anyone got any experience of the Samyang 85mm f1.4 (also sold under the Falcon/Rokinon/Vivitar/Bower names)?
Found myself needing a decent, fast, reasonably priced portrait lens and these are currently available at sub-£200.
Seem to receive generally positive reviews around the web, but just wondered if anyone on here owns/has owned one and what they thought.
Apparently.
Mike-P
Link Posted 05/02/2010 - 16:10
I have the lens under the Opteka name, bought it from this forum a few weeks ago along with a DA 70mm but to be honest I haven't used it as the 70mm does me fine on it's own .. I just don't need the extra speed.
It's a big hunk of glass.
. My Flickr
robbie_d
Link Posted 05/02/2010 - 16:14
Mike,
What are your thoughts on the build quality of the lens?
Apparently.
thoughton
Mike are they fully manual with no A setting?
Edit: on closer inspection I can see a red A
Tim
robbie_d
Link Posted 05/02/2010 - 16:15
Are there any other names this lens goes under?
6 so far...
Apparently.
robbie_d
Link Posted 05/02/2010 - 16:16
My understanding is they have an "A" setting but are manual focus only.
I could be wrong though.
Apparently.
thoughton
Link Posted 05/02/2010 - 16:17
I think you've got all 6
Yes, they are definitely manual focus only.
Tim
Mike-P
Link Posted 05/02/2010 - 16:50
I knew I should have posted this one showing the A setting
robbie_d wrote:
Mike,
Build quality very good, not so much the lens cap and hood though
. My Flickr
robbie_d
Link Posted 05/02/2010 - 16:52
This lens is apparently sold under the brand name Polar too.
7 brands for one lens, is this a record?
Apparently.
Mike-P
Link Posted 05/02/2010 - 16:59
I did put my Pentax AF 1.7x teleconverter on it and they seemed to work very well together, making the lens semi AF in the process
. My Flickr
robbie_d
Link Posted 05/02/2010 - 17:01
Good to know.
Apparently.
womble
Link Posted 05/02/2010 - 18:12
The manual focus forum folks have noted that the aperture ring has a habit of falling apart leaving the lens stuck on f/1.4... I'll try and find the link.
K.
My website
Mongoose
Link Posted 05/02/2010 - 21:31
although on a Pentax DSLR I wouldn't have thought that would be a major problem, since you wont be using the aperture ring anyway it shouldn't have any reason to break.
Of course those who still break out the film cameras every so often might have more of a concern.
but it does help
RR
Link Posted 05/02/2010 - 21:47
I have a Samyang branded 85mm.
As Mike says, build quality is pretty good, bar the hood & lens cap (which reminds me to pick up a "pinch" style cap for it. Focus action is better than alot of AF lenses.
I don't have any experience using it as a portrait lens, but you can see a few of my shots taken with it here there is also a "vivitar 85mm" group on flickr you may want to browse for portrait examples.
I'd certainly buy it again for the price, it performs very well.
My Flickr
JonSchick
Link Posted 05/02/2010 - 22:15
Mike - I was wondering when I was going to see some pictures by this lens, not of the lens!
As the previous owner, I'd back up what Mike says: decent build quality apart from the hood and cap (and I even included a centre pinch cap in the deal too....). Image quality is actually very good indeed, with quite neutral colours and surprising sharpness even wide open. At f1.4 it is rumoured to at least equal or even outperform much more expensive lenses - and the bokeh is exceptionally smooth.
MF is great - properly weighted and smooth focusing ring - but takes practice on dSLR because the viewfinder tends to give you the impression that you have more depth of field than you really have - wide open, things with any f1.4 MF lens can be a little hit or miss until you've got used to things. Live view can be very helpful here.
For portrait use it's an ideal length for 35mm, but perhaps the field of view is a little narrow on crop sensor SLRs - sort of the equivalent of taking 35mm portraits with a 135 lens. That said, get the focus right and make the most of that creamy bokeh, and the potential for great portraits is definitely there.
Jon
Some occasional random stuff at The Photographers Block: link
