Ricoh GXR with Leica M Mount - which lenses?
Must admit I didn't use it much, looking at the photos now maybe I should have given it a bit more attention.
Mudeford Quay by Mike.Pursey, on Flickr
Found one of it on the M5
Nokton Classic by Mike.Pursey, on Flickr
. My Flickr
@Mike: What did you make of the lens, especially compared to your usual Pentax lenses?
I'm not quite sure the novelty of having the GXR will last too long so it might not be worth spending so much when I've got a lot of cool Pentax options to put on the K-1.
All the gear with no idea
TBH I bought it on a whim, bit like you are doing ... to try a few adapted lenses. I even bought an adapter to try Pentax lenses on the M5 ... does the aperture as well.
DA* 50-135mm
Finlay by Mike.Pursey, on Flickr
. My Flickr
PPG Flickr
Some of the longer Leica lens like 90mm can be a bit got a bit cheaper
The zeiss lens are a bit more expensive but compared to Leica counterparts are a bit of bargin.
Another option in 35m focal length is the Voigtlander Skopar 35mm f2.5 - very compact and sharp.
I don't know whether I want any native M lenses now, unless I find a superb deal on something. I've overspent a tiny bit for sure.
The SMC Pentax-FA 43mm f/1.9 Limited lens was also made in Leica mount, although I don't know in what sort of quantities.
This used the Leica screw mount (adapter needed for M mount), they're usually searchable on eBay under 'Pentax-L Special' or similar. Some have the shoe mount 43mm viewfinder that was originally included.
Ricoh also made a Leica mount version of the original GR1 28mm (film compact) lens but again not sure of the quantities.
PPG Flickr
HarisF1
Member
Looking on the auction site I can find loads of lenses and many of them are very expensive!
I've also done the odd bit of googling and found one of our users has been through this before - it would be interesting to see if they can also reflect on their experience. Any input would be greatly appreciated.
