Remote F
Posted 29/05/2008 - 17:15
Why didn't i see this 1 week ago!
Posted 29/05/2008 - 18:45
Should have looked back two months ago.
I think a few of us pointed out that functionality.
Although, honestly with the strange behavior I see at times, I'm glad to see other's confirm that they have the same results. Dunno know for sure if that is a good or bad thing, but at least I'm not alone.
Posted 03/06/2008 - 15:19
I've been advised that it is useful to use a remote for steadier landscape shots. What's people's preferred option in this case... the cable release or as above the wireless remote f. What's the difference in their use?
Posted 03/06/2008 - 15:39
Other than those mentioned in the related threads, not much difference.
The cable remote obviously limits you to being within about half a meter from the camera (or buy/make an extension cable). The IR remote may not work well in bright sunlight or with certain indoor lighting situations.
Both help keep your hand from pushing the shutter release which of course helps eliminate vibration. So either will likely help a lot.
I generally find the wired remote more reliable and fires when I want every time, plus it has the ability for half-button press. The IR remote is full or nothing.
But putting the camera into 2 or 3 second timer also helps as it locks up the mirror before counting down. That will probably actually do more for you than either of the remotes, assuming the camera is on a solid mount to begin with.
Posted 03/06/2008 - 15:41
I always use a wired release in preference to a wireless one. They are more reliable, and you still get the two stage shutter release so you can engage the meter without tripping the shutter.
I would only use the wireless IR remote if the cable of the wired release was going to cause a major problem.
but it does help
but it does help
Posted 03/06/2008 - 16:04
Thanks for the swift response. The two stage release of the wired one sounds preferable, so I'm off now to get one. Cheers.
Posted 03/06/2008 - 17:13
I've only had the Remote F, and I've never had a problem. Quite apart from it doing everything I need, I like not having to open up the door on the side in order to connect it.I generally find the wired remote more reliable and fires when I want every time, plus it has the ability for half-button press. The IR remote is full or nothing.
On the K10D, of course, there's a custom setting that runs the AF before firing, so it pretty much gives you everything a 'half-press' gives you.
Posted 03/06/2008 - 18:03
of course that is one potentially important advantage of the IR remote Chris, well pointed out. You don't have to crack the weather sealing on the sealed bodies to use the IR remote. The seal on the little door is round the outside so with the door open the K10D's sealing is compromised.
Generally when I use a remote release I am actually still at the camera looking through the viewfinder, so I like the half press to engage the meter which you don't get with the IR remote.
but it does help
but it does help
Kent
