Recent light trails
Posted 21/12/2017 - 21:18 - Helpful Comment
Thanks for the info Derek - might give that a try sometime. I think the patterns are called Lissajou's figures
Andy
Posted 21/12/2017 - 23:22
Cheers Andy. Yep. That's what they're called.
Posted 22/12/2017 - 08:14 - Helpful Comment
Thanks......Interesting to see how this is done. I thought it was with mirrors
There's nothing new under the sun. These paterns were originally produced mechanically on a yoke called a 'Harmonograph'
https://www.google.co.uk/search?q=harmonograph&tbm=isch&tbo=u&source=univ&sa=X&v...
Posted 22/12/2017 - 08:23 - Helpful Comment
Thank you for telling us your method, simple BUT so very effective especially the examples that appear to describe a three dimensional form.
Enjoy a Christmas swing.
Posted 22/12/2017 - 09:38
Yea Algi, I came across those when I started looking this up, I think they were used for drawing patterns. Pretty cool stuff.
Cheers Nigelk, If I dont it wont be from the lack of trying
Posted 22/12/2017 - 23:08 - Helpful Comment
13 years
Wicklow Ireland
It is really basic, but here it goes,
You'll need a light, small led or similar, low watt, battery to power it and string.
Probably some kind of tape to keep stuff together.
I used bits i had lying around, which made it awkward, as i had under counter lights left over but they needed a larger batter to power them. so a large torch battery is what i used.
The lights were too bright, so i put them into an empty coffee tin and made a hole in the bottom to allow some light out.
Tie or tape the string to your lights and battery and hang it from a height. this is your pendulum. if you want you can make a double pendulum which will give you the cushion type results, i preferred the swirls from the single pendulum.
The length of string seems to dictate the duration of the swing more so than the weight.
Place your camera underneath, and away you go.
I generally set mine to f8-f13, iso 100, exp 30 secs to 5 mins
you need to shoot in the dark
hope this helps and would love to see what you get from your setup.
This guy is seriously into it.
https://youtu.be/n13Ij4NSNI8
20171219_190957 by dr.shutter, on Flickr
20171219_191109 by dr.shutter, on Flickr
20171219_190943 by dr.shutter, on Flickr
