Problems connecting and external monitor
Next problem
I've calibrated my monitor using a Huey, however, it's not been entirely successful. The colours are better, but I'm not seeing all the dark colours I should - either judging by the test card at the bottom of the screen (I see 15 not 16), or from images (eg. this, much of which I can't make out).
Is there some way of manually adjusting so I can see all the dark areas clearly (critical this as I often have dark areas in my photos).
Mhuni
500px
My Photobucket
b) make sure that your profiles are applied properly, and that you don't calibrate until the monitor and / or LCD has been on for a while (>30min); my calibrations get lost occasionally on this machine, whereas at work they're stable now I've set something up in Task Scheduler.
I'd check first that the calibration is correct for both monitors (and it's not using a setting intended for a different monitor) and I'd also suggest running the calibration whilst lying about the controls on the monitor. That way, the software will try and fix everything as opposed to manual controls which may not give you the results intended.
Vista is truly awful in comparison to 7 and I'd recommend anyone the upgrade: it's faster and far less likely to bluescreen.
Bret
my pics: link
Check out this article and some of the links in it. It is a good discussion on wide gamut monitors like ours. Your Huey calibrator probably came with different software to the stuff I use (with Blue Eye Pro), but the concepts are similar.
link
You'll see that when they tested the monitor in the link, the results of the calibration matched one colour space much better than the others. While that probably won't help the brightness, it can inform the choices you make with your monitor settings.
http://www.pbase.com/iberg
The latest is I have the resolution sorted out on both screens but only if I use one at a time not in Dualview (ie. two independently set monitors). If I attempt Dualview (either through my Nvidia control panel or Vista) it automatically resizes the other monitor, so that one is correct and the other incorrect (though bizarrely the resolutions aren't the same, as one might expect if it's doing this). For now I think I'll stick to using one screen just because it's simpler and I'm tired of all the hassle (for now at least).
Re. the calibration, this is a minefield - as I'm sure you're all aware
Out of interest, can anyone who reads this:
a. compare the Photofriday and PUF charts on their monitors and report back;
b. tell me what they can see in the shot here: link. On my Dell, the image is very dark outside the central area and blocking up in the BLC in particular where the smaller post exiting to the left edge is barely visible. On my laptop, the latter is clearly visible and the definition of all the posts is much clearer against a brighter sky (which is how I intended it).
Mhuni
500px
My view of your powerline shot matches how you describe in on your Dell. Very dark outer edges, and I can hardly see that left post at all. I didn't even know it was there until you pointed it out, and then I had to look from several angles to see it just like the 16th box in the footer here. (The shot looks great with these very dark edges, btw
Tim
let the education continue
No issue with the wedge, as T-T has indicated above.
Everything should be set to work on only one Gamma setting, and that should be 2.2 for a PC (1.8 for earlier MACs, but I believe later ones may use 2.2 just like PCs). NVidia's software should play no part in anything at all, otherwise its settings will conflict with that of your calibration software.
Your calibration software should at the least be able to tell you how accurately your monitor approximates that setting of 2.2 in terms of Gamma (although it will analyse a lot more besides).
If you have your monitor anywhere near correctly calibrated, at around 6500K, then you will see images darker than you'd expect. Esp. dark images if they are created on an Apple (using a different gamma to everyone else) and/or their monitor was not calibrated, or set for 9700K. These unfortunately are the the tradeoffs: have your monitor set correctly and see (some) images darker than you'd like; or join the masses and leave your monitor at its "shop" settings. The good news is that your calibrated monitor, all things being equal, should last longer at its calibrtated settings vs running full blast. And note that to view an image properly on a calibrated monitor you should be in a very subdued or unlit room, with no light sources behind you, and a shroud around the monitor is there are any other monitors on in the room. Only then will the colours/brightness look right. Indeed when we made photo-grade CRT's at Radius/SuperMac we included not only a shroud for the monitor but a neutral gray 'barber's style' smock for the user to wear!
And re this page, t-t is correct: there is no 100% 16th box. As John explained, even putting a 1 px white border around it to delineate it would be enough to fool your eye into seeing something other than 100% black.
My PENTAX Page
This was very interesting, thanks for posting! I had forgotten about the huge hoods some of those old Radius monitors had. Interesting read about the smocks too
This is not actually not correct. There are 16 boxes there, here is the code from the footer of each page on this website:
< div style="float:left;height:25px;width:25px;background:#ffffff;">
< div style="float:left;height:25px;width:25px;background:#eeeeee;">
< div style="float:left;height:25px;width:25px;background:#dddddd;">
< div style="float:left;height:25px;width:25px;background:#cccccc;">
< div style="float:left;height:25px;width:25px;background:#bbbbbb;">
< div style="float:left;height:25px;width:25px;background:#aaaaaa;">
< div style="float:left;height:25px;width:25px;background:#999999;">
< div style="float:left;height:25px;width:25px;background:#888888;">
< div style="float:left;height:25px;width:25px;background:#777777;">
< div style="float:left;height:25px;width:25px;background:#666666;">
< div style="float:left;height:25px;width:25px;background:#555555;">
< div style="float:left;height:25px;width:25px;background:#444444;">
< div style="float:left;height:25px;width:25px;background:#333333;">
< div style="float:left;height:25px;width:25px;background:#222222;">
< div style="float:left;height:25px;width:25px;background:#111111;">
< div style="float:left;height:25px;width:25px;background:#000000;">
Tim
bretti_kivi
Member
Work: Helsinki; Home: Lahti
Which OS? Win7 is a lot smarter than XP about this...
Bret
my pics: link
