Problem Focusing with Pentax SMC DA Series 50-135mm f/2.8 ED IF SDM
pschlute
Link Posted 31/07/2018 - 01:26
barkin wrote:
In which case, you'd simply set it back to default and you're back to square one, surely? No better - or worse - off than when you started.
You are correct of course. But call me old fashioned, I have always found it best to establish the actual fault first before attempting a fix.
derek897
Rear wheel. Afaik
pschlute
Link Posted 31/07/2018 - 01:30
RRattner wrote:
. I now know how to figure out whether i need to adjust up or down. The basic question i have is HOW to make that adjustment. I see it on the C4 menu screen (#27 AF fine adjustment) but can't figure out how to move it + or - on the scale. The 4 way navigation bar moves the menu to #26 or #28. How do you make the lens adjustment?
Don't have your camera , but on my K1 you need to use the down button first, then use the right/left buttons to dial in correction.
Mov to the right + to correct back focus, or to the left - to correct front focus.
