problem changing flash output on K50
Eain
Posted 08/05/2016 - 08:39 Link
I sometimes have a problem adjusting the flash output level on my K50. I press the flash side of the four way controller and it brings up the flash menu. I then go down to the output display just below. However it often disappears befoore I have time to make an adjustment - not always but enough to be annoying. I suspect I am making a very obvious error but haven't been able to identify it. Can anyone advise please?
McGregNi
Posted 08/05/2016 - 10:15 Link
Just a question, do you mean that the whole display of the flash mode page disappears, or just the Flash Compensation setting (the plus and minus values at the bottom) ? And what appears on the screen after it disappears? How long does it stay visible for before going off?
One thing, at least on the K7/K5 series, you don't actually have to select the flash compensation setting to adjust it ... As soon as the flash mode display appears you just turn the rear e-dial to make the adjustment. It may be that it's waiting for you to do something and just times out ... ?
Edited by McGregNi: 08/05/2016 - 10:18
Eain
Posted 08/05/2016 - 11:22 Link
Thank you for the reply.
When the flash mode disappears (and it does not happene very time) it goes back to the main screen. It only stays visible a couple of seconds. I have just tried it again and it is working perfectly. I wonder if sometimes the way I hold it when hurrying I may be touching the shutter button just enough have it revert. .
McGregNi
Posted 08/05/2016 - 11:38 Link
That's possible yes. You could check that behaviour by specifically not pressing the shutter button and seeing how long the flash screen holds. If you are fairly quick and make the compensation adjustment then I guess the screen should hold long enough to confirm its set properly.
There is a ' memory' item in the menus for flash compensation that will remember the setting when the camera is switched off. This could be handy but for many situations the default of 0 compensation probably makes most sense.
Eain
Posted 08/05/2016 - 13:25 Link
I think it is my own carelessness when holding the camera outdoors as opposed to testing it carefully. The screen does disappear very quickly if you touch the shutter button. I leave it at 0 compensation as you suggest normally. The K7 system seems more streamlined. Thanks again for your help.
McGregNi
Posted 08/05/2016 - 13:41 Link
You're welcome, hope you enjoy taking your flash pictures.
