Prepare for an onslaught of K5 questions
Yan Wang's 'Leap' project is going 'public' on tuesday - inviting people to jump about in the gallery for pictures...
Digital:
Flash:
Film:
http://www.flickr.com/photos/daveholmesphotos/
Digital:
Flash:
Film:
To be honest to me a grip is a grip. I took mine to pieces to see if it was weatherprooofed and if water was to get in there it would be difficult.
I bought a similar Chinese grip, just make sure it has the metal pegs like the one in the eBay advert has if you go for a fake one.
I have been very happy with mine and use it regularly in the rain, I have issues with my k-5 rear screen fogging up, but this is not caused by the grip.
Concert photography
Vertical shooting is something I do a fair bit of... Wish they just made dslr's with both horizontal AND vertical grips, with shutter buttons and control dials on each!!
Digital:
Flash:
Film:
K-5 is fab, but watch out for the electronic level issues; mine was fine for 6 months then the level went way off and caused issues with images (if this happens, make sure you turn off the automatic horizon adjustment in the menu). Other than that, the K-5 is a superb piece of kit and I had withdrawal symptoms when mine had to go back to SRS to get the level fixed.
What is the best way to test for this problem. Sometimes to me the camera just doesn't look "right" sitting on a tripod even if the horizon looks ok through the view finder.
Stan
Stan, the first test would be to out it on a surface that you know is 100% level, the check the level indicator in the 'Info' view (press 'Info' twice and it will display the level). It should be entirely central.
Secondly, if you have the 'Horizon Correction' switched on in the menu, and you take a shot that is 100% level in the viewfinder, but it comes out sloping on the image, you know there's a problem. Mine went from 100% accurate to about 10% off in no time at all and it had not been dropped or banged. I think it's something that just comes with the territory on the K-5 and Pentax clearly have not fixed it, even on later models which mine is.
Stan
Mine was not level so I just turned it off. I thought that sending the camera back may get fresh problems introduced that were not there to begin with.
John
Unless there's a very obvious natural horizon (like the sea, or buildings) to line up, I tend not to worry about the horizon indicator, and just go with what looks right to the eye.
I just bought a ballhead for my tripod, as I think this will be the quickest way to adjust for the type of shooting I do, and I have found the aircraft style 'Attitude Indicator' on the LCD very responsive. (This only came with the firmware update bear in mind).
I wonder if anyone has used the sensor shift horizon correction function? It is a very different way of working, I wonder if anyone has found it to be useful?
DaveHolmes
Member
Bradford
Used at a decent price with 1 year warranty via SRS
My K-x is sold to a friend and I no longer have a comicbook collection...
Will need a 18-55 WR kit at some point but the 50-200 will suffice at a 'wet-weather' kit for now
Digital:
Flash:
Film:
