pre-setting FL on manual zoom lenses
Given that the bird is moving quickly and a high shutter speed is needed, I turn off the SR system thus avoiding the slight delay waiting for it to stabilise.
(Janis Joplin)
KIT: K5iis, DAWR18-55mm,FA4.5 80-320mm, Mitsuki 5.6 400mm, M1.7 50mm, M1.4 50mm, M2.8 28mm, Miranda M2.8 28mm, M3.5 135mm, M1.4 200mm, Vivitar S13.5 70-210mm, Vivitar A 2.8 90mm macro,
Sigma150-500mm F5-6.3 APO DG HSM.
I did not know it is better to have the dialed in FL below the likely zoom used for the shot, than above. Why is that though (not questioning it, my brain just needs to understand why )
Of course the optimum is to set it at the actual FL you are using, but if this is impractical, then setting it to the lowest FL that you feel you are likely to be using may be better than setting it to an average.
(Janis Joplin)
11 years
Taynuilt,
Argyll,
UK.
(Janis Joplin)
