pk tether
Posted 05/09/2016 - 22:50
Don't know about EyeFi but The Pentax Flu one, is unusable for what you want imo. Way to slow to be of any benefit other than copying files off your camera. Think a good old field monitor would work better.
Posted 06/09/2016 - 08:20
OP - under what circumstances do you want to tether?
Posted 06/09/2016 - 15:45
My main reasons for tethering is for a check on my still life and portrait work. Not being able to tether is a serious disadvantage. I see that Nikon and Canon systems are available and to be honest if I had known that my photography was heading into this direction I would have given Pentax a miss when I upgraded my system a few years ago. I hear of pk tether working fine but I just can't get it working with my K5ii
Great photography is always on the edge of failure. - Garry Winogrand
Must stop myself falling over that edge all the time!
My Flickr
My Flickr
Posted 06/09/2016 - 17:12
I know it doesn't help your current setup but tethering with ImageSync on an iPad works a treat with models using wifi, and in one review I read it performs much better than the Nikon and Canon versions.
Posted 06/09/2016 - 19:54
I'd explore Mag07's suggestion of an external monitor, such as this one> https://www.amazon.co.uk/Lilliput-Panasonic-1920%C3%971080-Component-Composite/dp/B0050MVDV8
Or, maybe there's an app?
Posted 06/09/2016 - 20:07
Interesting product John - I'd be interested to know if anyone's used it for Astrophotography, I assume it can be used with LiveView (so you can check focus, composition, etc.) rather just as a review display for photos taken?
Posted 06/09/2016 - 20:33
It is for use with Live view as far as I know.
Posted 06/09/2016 - 20:54
Thanks John - I just need to do a bit of digging to see if any Astro-photographers use it and how effective they find it
Posted 07/09/2016 - 08:48
I have a Calumet 7 inch field monitor, which looks very similar (though was more expensive). I rarely use it. Probably more useful for video than stills and I don't take much video. The problem is that the screen is much poorer quality than the camera screen and when the monitor is attached it becomes the sole display - the camera screen goes blank. If working indoors with access to mains power a better solution is to use any TV with an HDMI input as an external monitor. Just connect to your camera by a long lead and you have a large, good quality image showing whatever would have been on the camera screen but much bigger, the only expense being the cost of the cable. No good for astro out in a field but a possibility for indoor work at minimal cost.
Regards, Philip
Posted 07/09/2016 - 12:06
Thanks for all the suggestions. To be honest I didn't want to spend much as I have to get a new PC monitor - and we all know how much photo editing monitors cost. I've ordered a new data cable as I think the one I was using might have been faulty. Hope that's the isssue. On the pk tether site some guy has stated that the software works with his K5 so I might post there. Seems tethering support is a weak area for Pentax cameras. It could seriously make me look elsewhere when I next upgrade.
My Flickr
My Flickr
Posted 07/09/2016 - 23:38
Use the TV - brilliant idea! I bought a very long HDMI cable to view the results from my armchair but it never occurred to me that you could use it to preview the shot beforehand.
Posted 08/09/2016 - 18:06
To repeat my earlier comment the tethering for the K-1 works a treat with a mini iPad giving a measure of remote control of focus and exposure settings as well as live view, and allegedly better than the opposition. Probably the same with the K-70. And if you have an iPad you don't need to buy a special piece of kit so put the saving towards your upgrade instead. I mention the iPad because it is handy and portable, but the Image Sync app could be downloaded to any suitable computer.
Posted 08/09/2016 - 19:14
Thanks to all. The range of different ideas was very interesting. I now have pk-tether working - it was simply a faulty data cable causing the problem. The software will certainly help me with my current work. I hadn't posted on the forum for some time and was obviously missing out on the expertise so unselfishly given. Thanks again.
Rod
Rod
My Flickr
My Flickr
Posted 08/09/2016 - 20:03
bookmarked for reference
Chris
Also is the Eye Fi card worth the money? I want to check composition. lighting and exposure on a laptop. I've read it is a bit slow with RAW which is what I shoot. Also I have Android an not an apple tablet.
Many thanks
My Flickr
