Pixel shift post-processing
Posted 02/01/2021 - 07:30
I think that Rawtherapee does a better job with pixelshift than the Adobe programs..
Davek
Davek
My PBase: www.pbase.com/davekitson
Posted 03/01/2021 - 16:00
Mike-P wrote:
To be honest it's impossible to see if they are sharp because of the size.
Pixel shift is something I have always meant to try but never got round to as my preferred software (DXO Photolab) doesn't process it.
Fair enough, here are crops from each which I hope will show how much detail is captured.To be honest it's impossible to see if they are sharp because of the size.
They were all taken on a tripod with a DFA 24-70mm at the longer end and aperture f8 to overcome the difference in distances between the centre and edges of the frame, in live view and a 2 sec. delay on the shutter.
Posted 06/01/2021 - 18:35
Don't generally use pixel shift as I'm unsure if Lightroom can process them?
I bought my K1 used from Wex I think from memory and it didn't have the Silkypix CD
Posted 06/01/2021 - 21:27
Gareth, I find pixel shift works fine normally in Lightroom but for some reason the ones I took above wouldn't sharpen. There could be a couple of factors, I was using autofocus in live-view in rather poor light and the exposure times were between 1/4 to 1/10 sec so maybe a tiny bit of wobble although they look fine on the back of the camera. The Unsharp Mask in Photoshop has some sort of smart function which I think compensates for whatever is causing blur because there are other menu options to correct blur caused by camera movement and lens issues.
If you are shooting a static object like a building or still life it is definitely worth giving it a try, use a sharp lens, get everything right and the detail is amazing.
Posted 06/01/2021 - 22:32
Thanks Rob,
I'll give it a go
I'll give it a go
Posted 07/01/2021 - 00:13
This is a straight reaction to looking at the images: they appear to have the most amazing textures - almost every grain of sand and tiniest bit of moss. I would expect pixel shift to produce this - detail to the 'n'th degree! However, is all that microscopic detail actually swamping the major detail of the entire gravestones? It's like looking closely at a pointillist painting. All you see is dots, until you step way back. Have you any non-pixelshift images to compare them with? Of course, I could be talking complete rubbish. It wouldn't be the first time!
Posted 07/01/2021 - 07:44
Fair point David, these are part of a series exploring how time and the weather are gradually wiping away the lettering, in an analogy of the loss in human memory. The subject matter I want to focus on is the texture, lichens and other growth rather than the full details of the person interred which are often illegible anyway, and with the idea that these could be printed quite large.
Posted 08/01/2021 - 18:21
Is there any in-camera facility for processing pixel-shift files, even if it is just assembly into a single initial image?
Regards,
Kea828
Kea828
Posted 08/01/2021 - 21:37
The four images are automatically combined into a single file in the camera which you process like a standard image in appropriate software. I believe where other manufacturers have a similar feature they are retained as separate images which have to be combined afterwards in special software (if you can identify them amongst the photos on your card).
Posted 09/01/2021 - 11:42
The four images are automatically combined into a single file in the camera which you process like a standard image in appropriate software. I believe where other manufacturers have a similar feature they are retained as separate images which have to be combined afterwards in special software (if you can identify them amongst the photos on your card).[/quote]RobL,Is there any in-camera facility for processing pixel-shift files, even if it is just assembly into a single initial image?
thanks for the clarification.
Regards,
Kea828
Kea828
12 years
Warwickshire
