Pentax M 100mm f/4 macro PK-M
HTH. K.
My website
It will fit but you'll have to use stop-down metering which is, to be frank, not very accurate. OK for flowers as you can shoot, look at the histogram, adjust, and shoot again but probably less helpful for bugs that don't tend to hang around while you adjust the exposure. An 'A' series lens would still be manual focus but easier on the exposure.
HTH. K.
Thank you Kris I did wonder if I would have to do this, I don't want to spend ages with it and loose the moment while busy adjusting the exposure, Will have a look for an A series one instead of this one this is £139.00 do you think that its expensive as I really haven't an idea of whats a good price for a macro lens.
Best wishes Trixie
It is an oldie but 'goodie' subject to the following:
Heavy
Manual only (exposure and focus)
Not a true macro (maximum reproduction ratio is 1:2; 1:1 or life size requires the use of an extension tube)
Not, IMHO, the best lens to begin with unless you are mostly interested in photographing static subjects or intend to use it mainly for work under controlled conditions indoors.
Having said that, if you are being offered a 'mint' copy at a bargain price (£75.00 or less) it might be worth buying.
Jon
[[quote]Trixie xx If at first you don't succeed, try, try again,then quit. No use being a damn fool about it. W. C Fields.
you would be better off if the lens you are interested in has a bayonet fitting
Trixie did say it was a PK lens David, in the topic title
As for Macro lenses Trixie you could also consider the Tamron Macros, they can be every bit as good as Pentax and can be picked up for quite a reasonable price in KA mount too.
My PPG link
My Flckr link
Hi Alan, have a look at Trixie's reply in the post above mine. You'll see that she makes reference to 'hoping it hasn't got a bayonet fitting'. This is why I posted the comment.
Y'know I noticed that just after my post, I was rather hoping you wouldn't notice
No worries, hope you sleep well!
Hi Alan, I have a sigma lens with a bayonet fitting and it wont fit my K-x I'm going to have to re think this one,, might have a look at a tamron as I have a Tamron wide angle lens that I really like,
Thanks to everyone Cheers Trixie
All the Pentax branded bayonet lenses will fit your K-x so these will not be a problem. It's best of you choose one with a Ka bayonet though, so that all the electronics couple with your camera and you don't have to mess about with manual settings.
You can tell suitable lenses as they will have electronic contacts on the mount and an "A" setting on the aperture ring. This includes all manual focus SMC Pentax-A lenses and all autofocus ones.
If your sigma lens does not fit K-x it is either:
1)Faulty (or damaged)- possible the mount is bent slightly...
2)bayonet fitting (but not K-mount - perhaps nikon-F or olympus...)
3)M42 (screw thread (this will work on K-x but will require an adaptor..)
With regard to your search for a macro lens...
I too would really love a decent macro and intend to save for either a Tamron 90mm macro or a Pentax-FA 100mm f2.8 macro lens... But looking at around £300+
Digital:
Flash:
Film:
http://www.flickr.com/photos/daveholmesphotos/
Are you sure your Sigma lens is a Pentax bayonet Trixie? There are many other types of bayonet fitting for different makes of camera.
Thank you John for the information I have looked at my old sigma lens and it does fit i had to go to the settings and adjust the settings in the menu to enable, so this fits now. I have had it for a while and never used it ! but I will now. thanks again for the help. Cheers Trixie
trixie
Plus Member
Sheffield
Best wishes Trixie
